New Guy Needing Advice on Purchase
   / New Guy Needing Advice on Purchase #1
bobbyspaghetti
Fort Saint John, BC Can
shopping
So I am new here wanted to say hello. I am a long time forum goer, not for tractors mind you but I know if you want an @$$ load of information on a topic a forum is where you want to be.
So I am in the market for a tractor. I recently bought a home on 10 acres and have no mechanical workhorse. I live in Fort Saint John BC Canada and it gets cold here and snows quite a bit. The drive way to my house serves two properties is quite long lets say 300 metres give or take. The drive way is gravel and we get lets say 5 feet of snow fall or more each year. I also have in the neighborhood of 8 acres of lawn. With my little husqvarna ride'em mower it takes me 10-12 hours which to me is warming up on too long.
So I was wondering what you would recommend for a tractor for 10 acres for lawn mowing and snowclearing. I am thinking a cab is a must as it is cold here for over half the year and is also quite windy. I am also told that a snowblower is the way to go as a FEL for that much is not optimal. A cowoker has a montana tractor with a 3 point hitch pull behind blower. He said he loves it but there are days he wishes he had a cab but loves the blower as he does not have to worry about where to pile snow.
I have my eyes on a Kioti ck35 with cab and would purchase a rear pull forward snowblower and finishing mower. I however am just baseing this off the little research I have done and just what I think. That is why I came to see the experts. I would also use the tractor for just general yard stuff and will ultimately have a shop to fool around in and will use it for odd jobs along those lines.
Please feel free to let me know what your thoughts are on my very unorganized list of questions based on the very unorganized information I have provided. Please feel free to bash me for leaving out important information I should have mentioned.
   / New Guy Needing Advice on Purchase #2
Sounds like you are looking at the right size tractor for your needs.
A 35 HP machine will run a 6 or 7' finish mower .
I finish mow 7 acres of lawn with a DK 35 with a 7' rear discharge finish mower in around 3 1/4 hours..
Nice good to hear I didn't think I was too far off. I appreciate the quick response anyone else have nay other thoughts? Thanks Vince 3 hours seems like a much more manageable time frame. I mean I love mowing the lawn but not that much.
   / New Guy Needing Advice on Purchase #4
Vince, What brand finish mower you use???
   / New Guy Needing Advice on Purchase #5
:welcome: to the forum.
Well I was going to suggest a cab but I see you are already thinking about one. Cabs are great. I know some of the guys on here get tired of hearing me say this but the Kioti CK35 can have a sticking hydro pedal. I have experienced it first hand so I would not recommend one. A CK35 size tractor is getting pretty big to be mowing around your house especially if you went with a rear finish mower. If you decide to go with that size tractor you may want to keep your current mower for around the house. Do you have a gravel driveway? I am not really sure if a gravel driveway would work good with a snow blower. I just got plow my driveway the first time tonight with my loader mounted plow and since the ground was not frozen it was cutting in at times so if I had a blower I would have been throwing rocks and shearing bolts. I have heard of some guys on here that say a pull type blower does not work good on a compact tractor. I guess you would be fine with 12-16" but if you got a couple of feet you would have a hard time getting though the deep snow.
I am partial to Kubota so something like a B3000 would be a good option. You can get a 72" mid mount mower and you may be able to do all of your mowing with it. you could get a loader mounted blade or rear or front blower for snow. A Kubota L3940 would also be good but to big for mowing around your house. You could pull a 6' or 7' finish mower. You could get a blade for the loader that use the skid steer quick attach or you could also run a blower.
If you were looking at a John Deere a 3520 would be another option with a 6' mower and a blade or blower.
Here is a calculator for mowing time.
   / New Guy Needing Advice on Purchase #6
First Choice GM35-84.
I believe it is the same mower(made by Sicma) that Kioti was using/rebranding for their mowers for several years.
   / New Guy Needing Advice on Purchase #7
Thanks Vince and Merry Christmas
   / New Guy Needing Advice on Purchase #8
I agree with Roger, that the 'pull type blower' with the CK35 might not be the best option. All you need is one big snowstorm to shut you down. While 13.82 inches ground clearance sounds like a lot, just be prepared to be out there every couple of hours if a big storm hits.
Other than the blower style........the CK35 should do all you need.
EDIT: Does the tractor you are looking at have an FEL(front end loader)? If not, you might want to find a tractor that does. An FEL is indispensible (IMHO).
Yeah definatly agree. I wont purchase with out FEL. Our snow is super dry up here and I can drive our 1/2 ton trucks through the snow and my neighbor uses his old school case 2wd and unless he falls off the drive way into ditch he seems fine. I appreciate the input though but I would be plowing before it got more than a foot or I wont be getting my *** to work in the morning. I am worried now the weight of the CK35 with cab mixed with industrial tires may make a mess of the lawn put really don't think I could snow plow efficently with much less tractor. Maybe put antifreeze/glycol in tires in winter and helium in tires in summer. That of course was a joke.
   / New Guy Needing Advice on Purchase #10
If you have an FEL, you should load the tires, or use wheel weights............and then they also recommend a ballast on the 3pt.
Behlen 150 Gallon Premium Stock Tank (A55218)
Behlen 150 Gallon...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
2019 Allmand Bros Maxi-Lite II 15kW S/A Towable Light Tower (A52377)
2019 Allmand Bros...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
