New HID Worklights on BX2660
   / New HID Worklights on BX2660 #1
Dunlapjc
Just wanted to share some pictures of the work lamps I've installed on the orange beast. They came out great!
6000 unadulterated lumens blasting out into the darkness...
I used a modified Osram Sylvania Xenarc X1010 High Intensity Discharge (HID) Xenon Lighting System that has had the bulb shield removed. Although that makes it a glare hazard for on-road use, that's not my intent, and getting as many lumens projected out was my goal.
Each ballast went behind the tail lamps, the power switch for the rig is an IP65 rated LED lit rocker switch that fit perfectly on the plastic flat next to the cup holder.
These are un-edited pics off of my phone, so the comparisons to the stock headlamps are apples to apples, and the night shots are just that, straight shots from the phone.
I'm throwing a lot of light, I'm thinking of this would be a fun way to play late night back-yard wiffle ball tournaments...
Certainly not a conventional set of work lamps, and my wife certainly thinks its overkill, but what fun would a conventional setup be...
   / New HID Worklights on BX2660 #2
Warning!; Looking at the enlarged versions of the above photos may damage your vision! ;)
   / New HID Worklights on BX2660 #3
Nice! don't you need a rear facing light too for backing up?
There's enough light spill that I can actually see behind me...
(as long as I don't look up and blind myself.
Also, I mounted the work-lights on a bracket that can swing over and shoot backwards if wanted.
   / New HID Worklights on BX2660 #5
Have to agree with your wife, those lights are overkill, but if you are going to kill something it's nice to see what you are killing. LOL I sure hope you have the 40A alternator on that beast or your battery is going to be toast in short order.
Regards
DGS
I do have the 40 amp alternator, but since they're HID they start out at 8 amps each, but then within a minute they reach steady state run current at 2.3 amps each. That's the beauty of HID. The initial power draw is high to start the arc, but it drops drastically in short order...
HID is more energy efficient than Halogen, but LED is even more efficient than that, but more costly at this point...
Regards
DGS
   / New HID Worklights on BX2660 #7
there is no such thing as overkill! lol
Nice job. No need for a snow blower now eh, you can just melt it.
   / New HID Worklights on BX2660 #8
Nicely done and great results. I was sittin at home wondering how I could effectively work a little longer and came across your post................ Thanks
   / New HID Worklights on BX2660 #9
Hmm, I may have to stop by a certain HID Engineers desk tomorrow.
   / New HID Worklights on BX2660 #10
Just stumbled onto your post about the HID lights- amazing! Is there another thread, "cause I love to read more about the lights themselves, like how much they cost, where they came from, etc..
   / New HID Worklights on BX2660 #11
   / New HID Worklights on BX2660 #12
Nice set up. But w/ the lights up on top don't you worry about ripping them off on branches or something?
j
   / New HID Worklights on BX2660 #13
Where did you get these lights? I tried to search the internet for them but it looks like they have not been listed for sale for a few years now. I would love to get a set if the price is right.
I had a set from an old project...
I've seen them on ebay and other sites from time to time.
I set it up with the mounting harnesses so I mount them as high as possible in winter to shoot the beam pattern over the snow blower onto the ground, and in summer I can flip them around to have them under the ROP bar to protect against tree limbs and such...
That was my logic,
-Jon
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2016 Freightliner M2 106 Altec AM50 50ft. Bucket Truck (A59230)
2016 Freightliner...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2008 CAT D4K XL (A58214)
2008 CAT D4K XL...
2008 Toyota Camry Sedan (A59231)
2008 Toyota Camry...
