new holland 269 baler
   / new holland 269 baler #1
banjerpicker
Does anyone know the size of the U joint on the 269 baler's PTO shaft? I measured one inch by 3 1/8. does that sound right? When I went to TSC and AutoZone they all seemed to be metric
Larry
   / new holland 269 baler #2
I went to new hollands site and to the part look up section.
https://webparts.pvassociates.net/cnh/launch.php?DealerID=PVA-9SYXB-FBC3&DataSet=001NHNA
I input 269 in the model search box and it gave 2 choices
Front PTO:
Rockwell PTO standard
item # 7
NH part # 129437
or
NEAPCO PTO
Item #6
NH Part # 47621
Rear PTO:
Rockwell
Item # 7
NH part # 129437
or
NEAPCO PTO
item # 7
NH Part # 47621
It could be a good thing to take the NH part number with you and any partsman worth anything will be able to cross to another brand.
and if they cannot cross it directly...a real parts store will have a catalog (behind the counter for the employee) that will give the size of the NH part so you can match it by size
   / new holland 269 baler #3
Here is a NEAPCO pdf cross reference chart
http://www.neapco.com/nA-aftermarket-catalogs.php?pdffile=1
if you look under new holland and see part 47621
it has another number to the right of 1-1875
I believe (I am not 100% sure tho) that this is a standard number for most lines of u-joints.
If you google 1-1875, you find many brands of u-joints with that number
the rockwell number of 129437 has the number 1-2075 to the right.
Thanks for the info. I will track one down today. My baler looks so sad in the field with hay ready to bale and it's broken. It was making some great bales yesterday. I finally got the tension on the bale adjusted. Good for a baler that is over 40yrs old.
Thanks again for the help
Larry
Got it at NAPA store
A good neighbor helped install it
Works great
Thanks for the help the cross ref on part was a great help
Larry
16' Farm Cart (A57149)
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56436)
Case Wheels for...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
Ford Engine & Transmission (A57149)
Ford Engine &...
2002 Ford F-150 Pickup Truck (A56858)
2002 Ford F-150...
Approximately 10 Sheets of 9ft Tin (A57454)
Approximately 10...
