New Holland 56 Hay Rake Tine Bar Bearing Help
   / New Holland 56 Hay Rake Tine Bar Bearing Help #1
scottstein06
Farmall 1206
Bearings went out on one of the tine bars on my 56 hay rake. Replace bearings but now I cant get the studs on the bearings to go back in the starwheel. Is there a trick to doing this? I tried leaving one side loose and getting the other end in and pushing on the bar in the center, all with no luck.
Any help is appreciated! Thanks
   / New Holland 56 Hay Rake Tine Bar Bearing Help #2
Leave the bearings on both ends of the bar you are working on loose.
Loosen the 4 bearings on the 2 bars opposite the one you are working on.
Loosen the center hub of the RH star.
Put it together.
UNUSED FUTURE XJ3T 3TON 30" HYD THUMB CLAMP (A51248)
UNUSED FUTURE XJ3T...
UNUSED FUTURE HYD THUMB CLIP (A51248)
UNUSED FUTURE HYD...
UNUSED CFG INDUSTRIAL QK20R EXCAVATOR (A51247)
UNUSED CFG...
2003 Pace American Trailer, VIN # 4FPW540373G068816 (A51572)
2003 Pace American...
2023 Bobcat E32i Mini Excavator (A51573)
2023 Bobcat E32i...
2015 Kubota KX71-3S Mini Excavator (A52377)
2015 Kubota...
