New Holland 5640 12x12 stuck in Mid range
   / New Holland 5640 12x12 stuck in Mid range #1
JMikeWilson
Catlett, Virginia
5640,6640,TS100,5030,4600
Hello all,
My daughter's 5640 with the 12 speed has stuck in mid range. I disconnected the shifter from the side of the trans and it is free; the thing has stuck inside. Before I plunge into exploratory surgery has anyone else fixed this problem already?
Thanks,
Mike
   / New Holland 5640 12x12 stuck in Mid range #2
What did you find and how did you fix it, mine is stuck in low range.
Thanks,
Jim
What we found was that wear in the shift linkages, just a little at each joint, was adding up to the lever not fully moving one fork all the way out of gear before starting to engage the other. Fixed without splitting the tractor, but we did pull off the side cover through which the shifters pass. Not sure that was totally needed though. Might first try tightening up all the external stuff.
2003 Lincoln LS (A50324)
2003 Lincoln LS...
2012 CATERPILLAR 308E CR EXCAVATOR (A51246)
2012 CATERPILLAR...
WORKSAVER RMB-325-PW LOT NUMBER 117 (A53084)
WORKSAVER...
2022 John Deere 8R 340 MFWD Tractor (A53342)
2022 John Deere 8R...
FRONTIER WR3212 LOT NUMBER 57 (A53084)
FRONTIER WR3212...
LMC LOT NUMBER 254 (A53084)
LMC LOT NUMBER 254...
