new holland 650 not tying
   / new holland 650 not tying #1
Simpkins85
Bronze Member
I have a New Holland 650 round baler with auto wrap on it and it will not tie the arms will not go back to home position when I hit the manual trip lever it does noting any suggestions ?
   / new holland 650 not tying #2
check the little roller that is under the trip plate assy. i just worked on one that was having the same problem and all it was is the roller was froze up because there is no way to grease it your best bet would be to check that and most likely if that is the problem i would change the plate and roller to the new style i would also check the bushing in the pully for slack and change them while working in that area
Would that have anything to do with the trip lever when you trip the lever it will not come back up you have to push it up?
   / new holland 650 not tying #4
yes if that plate is wore at it will be loose and not catch when it comes around
The plate you are talking about is the one that moves when you hit your trip lever right or is it another one ?
18ft Refrigerated Box for Cab and Chassis Truck (A51573)
18ft Refrigerated...
2018 AMERICAN HAULER (A52576)
2018 AMERICAN...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2022 Harley-Davidson FXLRS Motorcycle, VIN # 1HD1YWZ11NB021297 (A51572)
2022...
