3-Point Hitch New Holland TC29D PTO not disengaging
   / New Holland TC29D PTO not disengaging #1
fred.hayfarm
New Holland TC29D
I ran my rear mower for about 15 minutes and then headed to the barn as weather was coming. I set the engine RPM to 1500, stepped on the clutch and pulled back on the rear PTO lever. It seemed to come back OK. I did not hear anything from the mower and thought it had stopped turning. On the way in I noticed the PTO instrument panel light was on. With the clutch depressed I pulled back a few times on the lever with no change in the light. I did not try to re-engage the PTO. I figured I could work on it next day, so I shut down the tractor (mistake!). Next day the tractor would not start due to PTO interlock (light still on). I could move the PTO lever forward an inch and back. The lever going down to the gearbox is clear. The PTO fuse is good. The tractor has 500 hours. I got it at 400. The PTO and FWD levers have always been hard to move, but worked OK. Is it even possible to move those levers without the engine turning? I also noticed that the clutch pedal depresses but the connecting rod back to the gearbox does not move. Is that normal with the engine off? I am considering lifting the rear tires off the ground to see if turning them might free up the transmission so I can fully disengage the PTO. Is that realistic?
Other ideas? Thanks!
   / New Holland TC29D PTO not disengaging #2
Almost sounds like a sheared key on the clutch pedal shaft where the connecting rod attaches.
   / New Holland TC29D PTO not disengaging #3
There is a wiring harness connector in the left rear wheel well. Check and make sure it is connected, or the light will come on all the time and cause a no start situation.
Thanks, showcattle! I had looked and looked on my back with a flashlight up through a nest of wires and linkages, and I couldn't see the problem. However, I had someone else give it a try and they found the disconnect. How that disconnect happened is a mystery. How I couldn't see it is also a mystery, but that is another problem. Your help much appreciated.
   / New Holland TC29D PTO not disengaging #5
The only reason why I know is because I was stranded in the woods when the same thing happened. PTO light was on, and tractor wouldn't start. I suppose a limb or something pulled ours apart while we were cutting firewood.
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
198367 (A51243)
198367 (A51243)
2017 FORD F-250 SUPER DUTY (A52472)
2017 FORD F-250...
