new holland tc33 clutch issue
   / new holland tc33 clutch issue #1
gclark
Mount Airy, GA
New Holland TC33, Ferris IS700Z Zero turn mower
I have a new holland tc33 that I think has a clutch problem. When I crank the tractor and press the clutch in to put it in gear it grinds the gears, I have talked to the local dealer and they said it sound like the clutch was stuck or the hub assembly that the throw out bearing is on is stuck. I took the tractor apart and found that the hub that the throw out bearing is on was indeed stuck. I removed the hub assembly and throw out bearing and sanded and lubed with a silicone lubricant. I also looked at the clutch assembly and it appered to be ok. I put back together and still had the same problem. Pulled tractor back apart and pulled the clutch off and it looked like it may have been stuck, lightly sanded clutch and pressure plate to remove rust and put back together and still have the same problem. When I put the clutch back in, the fingers that the throw out bearing press against looks like they go back to a flat positon, should these fingers be pointed out toward the throw out bearing? I think I need to replace the clutch assembly but I am not sure. I am doing the work myself due to the cost of having a dealer do it. Any info./help would be greatly appreciated.
   / new holland tc33 clutch issue #2
Hello
When it is installed the pressure plate fingers will flatten out some.
It is putting tension on the clutch plate.
Have you adjusted the linkage to get about a 1/2 inch of pedal free play at the top?
As far as replacing the clutch, are the rivets below the contact surface?
If the plate is not oil soaked or burned it is probably ok.
It sounds like it just isn't releasing properly. Which can be that it isn't adjusted correctly.
You have corrected the sticking issues and if you put it back together right I think I would check the pedal free play.
If there is an inspection cover , have someone push the clutch pedal while you look to see if everything is ok.
Hope this helps.
New/Unused Pallet of 5 Binder and 10 Chains (A44391)
New/Unused Pallet...
2021 Case Trident 5550 Spreader (A46878)
2021 Case Trident...
Klemmfix Qwick Curb (A44571)
Klemmfix Qwick...
2017 Yale GLC050VX 3,500 lb LPG Forklift  Powershift, Aux Hydraulics (A46877)
2017 Yale GLC050VX...
Heavy-Duty 4-Wheel Rolling Warehouse Cart  74in x 32in (A46877)
Heavy-Duty 4-Wheel...
2023 Bobcat E32i Mini Excavator (A44391)
2023 Bobcat E32i...
