New Holland TC35D Locking in FWD
   / New Holland TC35D Locking in FWD #1
r.bianchi
New Holland TC35D
i am having a problem going from auto FWD to Locking it into fulltime FWD. is there a sequance for getting this to lock in. possible a cable issue from lever to transmisssion? note i have HST transmission and supersteer,
Thanks in advance for your help
Ron
   / New Holland TC35D Locking in FWD #2
There is no auto 4wd on a tc35d with hst 2wd or 4wd only.. If you have a loader raise wheels off ground then shift. Probably wheels are in a bind. 🍻
   / New Holland TC35D Locking in FWD #3
The lever on the left console controls the engagement of the full time 4wd. The lever has a spring which then attaches to a cable that runs to the right side of the clutch gearbox directly behind the front differential. You need to check that the lever on the side of the clutch gearbox moves freely so that the clutch will engage when the cable is pulled. Raise the front wheels off the ground and put pressure on the lever while slowly turning a wheel to see if it engages. If it does, and the lever moves freely. you may have a broken spring or broken or frozen cable.
Thanks for your help I will check the cable and spring
Ron
2016 Dodge Journey SUV (A53424)
2016 Dodge Journey...
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
2011 Chevrolet Traverse 1LT SUV (A53424)
2011 Chevrolet...
2018 JCB Truss Jib Telescopic Hydraulic Boom (A53421)
2018 JCB Truss Jib...
2018 CATERPILLAR 415F2 IL SKIP LOADER (A52705)
2018 CATERPILLAR...
2022 Padget Morris Electric Mobility Scooter (A54815)
2022 Padget Morris...
