Kregan87
I have a 270tl fel on my tn55 and has been real powerful until this past December. The loader started to be really slow and weak. Mostly on the lift pistons but a lacking a little on the curl also. I figured it was real cold hydraulic fluid but warmer temps haven't helped.
So far I have check my hydraulic pressures at various locations and at wide open throttle I am only getting 1000psi. Can even pick up a bucket of snow. Last year I was picking up massive buckets of sand and stumps with ease. I'm not sure exactly what pressures should be but the relief is supposedly set at 3000psi. So I figured I should probably be getting about 2600-2700?
I've changed hydraulic filter without any luck also. Any one have any ideas? at this point I'm thinking the pump is shot. Please any help will go a long way. I check pressures out on both sides of lift pistons, curl pistons and both sides of the loader control valve. All pressure max out just under 1000psi.
