New Holland, TN75, code 39
   / New Holland, TN75, code 39 #1
rollyacres
New Holland TN75
My New Holland TN75 will not go into reverse. It moves forward just fine. It is displaying code 39. Does anyone have an idea how to fix this?
   / New Holland, TN75, code 39 #2
Don't know anything about it myself but I would have disconnected battery let it sit a while,connect back up for starters and see if that "fixed it".
Someone here will know.
Boone
Thank you for your suggestion... I did already try disconnecting the battery, and seeing if that would restore the functionality of the reverse, but that did not work....
   / New Holland, TN75, code 39 #4
PM SENT
Boone
   / New Holland, TN75, code 39 #5
I experienced a similar problem which was traced to a bad ecm. Its nothing you can fix yourself if thats the problem. If it is the ecm prepare yourself for a very expensive repair bill unless you can convince NH to help out.
2025 BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
10222 (A56858)
10222 (A56858)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
1992 BYQ Boat and Trailer (A56859)
1992 BYQ Boat and...
2015 Ford F-350 Cab and Chassis Truck (A56858)
2015 Ford F-350...
