New Isekin owner, needs manuals and filters
   / New Isekin owner, needs manuals and filters #1
eppoh
Texas
Iseki TS1610
Hello all,
I am new to tractors and Iseki. Just bought a low time Iseki TS1610 that needed a radiator. Has pretty new Maschio mower on the back.
In the process of getting a few things taken care of. The tractor sat out under trees for years, so faded a bit, but running good other wise. Just put a core in the radiator.
I have no manual for it and the labels on the controls are gone. Only one of the dash lights work ( one on far right)
Can't find air or oil filter applications for it . I like Wix.
Any help and advice appreciated.
   / New Isekin owner, needs manuals and filters #2
The air filter is hard to find. I recommend you remove your air filter and measure the distance from the screw mounting point to the bottom of the housing. Mine measured 9.25inches. I just installed a Fram CA3659SY air filter in my TS1610. It fit but is a $30 air filter.
Some people use a Fram CAK530 air filter. That is a shorter air filter. 7.25" total length. I think with CAK530 they use a custom spacer made out or metal or plastic to fill the rest of the length, or they modify the filter mounting bracket. The advantage is the CAK530 is a $15 filter.
I used a Fram PH3600 oil filter. This has 3/4-16 threads. Some posts on this site claim the TS1610/1910 have metric 20mmx1.5mm threads on the oil filter.
When you change the oil filter take a close look at the size of the mating surface of the gasket to be sure you have the right diameter filter gasket. The Wix 51568 & Napa 1568 are mentioned in some posts as the 20mmx1.55mm thread filter that will fit.
I bought a WIX oil filter that is supposed to fit the Isuzu 2AB1 engine, which I think is the same as the 2AA1 except for the injector pump and max rpm. Have not installed the wix yet.
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2015 MACK ELITE LEU 633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
2019 Dodge Journey Crossroad SUV (A50324)
2019 Dodge Journey...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
