rossn
I received my King Kutter XB tiller last week, and just finished setting it up. Looking forward to using it!
As I went through and checked the gear boxes for lube level, when I removed the check plug for the side gear box some light fluid, watery consistency, came out first, then the OO grease started to ooze out behind it. Maybe a tablespoon or two of liquid came out, and was easily soaked up by paper towel. I didn't want to run it until I understand this better. Any ideas on this?
Also, how do you know when you've added enough grease to the 'outboard hub'? Does it squeeze out from somewhere?
Lastly, how much grease is typically needed for the pto shaft covers? There are two plastic zerks, and I'm not sure if you just put a squeeze or two in, or if you need to see it come out somewhere.
Paint and sticker job is lovely! When I gently removed off the packing slip envelope that was stuck to the gearbox, the paint came right off with it.
