New machine with scoring on bucket pins
   / New machine with scoring on bucket pins #1
jmfox
Platinum Member
I have about 70 hours and notice that one of the pins for one of the curl cylinders is scored in about mid way. Is this something to be concerned about. I've greased it every 12 to 20 hours, so I suspect it is a defect.
jmf
   / New machine with scoring on bucket pins #2
How did you find out about the scoring? Removed the pin for a different reason?
Scoring is from lack of lube and high pressure. Misalignment, mis-sized bushings or dirt can be the reasons. If you have the pin out, I'd check the bushing too.
jb
I replaced the cylinders because of defective welds, so they are new. My concern is that the scored pin might cause a problem with the new bushing.
One thing I notice when greasing machines is that often grease pours out of one end of the pin, and no matter how much grease I add nothing flows out of the other end. When this happens I wonder if grease, for whatever reason, is only getting to one side.
jmf
   / New machine with scoring on bucket pins #4
I'd replace the pin.
jb
jb
That's what I'm thinking, I hope the warranty department understands that it was caused by some design defect that didn't allow 1/2 of the pin to get lubrication.
jmf
John Deere 333E (A47477)
John Deere 333E...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
UNUSED Clear Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Clear...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
2239 (A51244)
2239 (A51244)
