New member near Houston
   / New member near Houston #1
donpeak
New Caney,Texas (Houston area)
Zen Noh ZL 1501 with loader and Modern brush hog
Hi
Just found this web site and purchased a used Ken Noh 1501 from a neighbor who bought a new Kubota. They say this gray market tractor is nearly
identical to a Kubota 175 (late 70's-early 80's)
My goal is to use this tractor occasionally to assist my decking crew to put fill sand around my swimming pool projects amd to help others do a clean-up
after the pool is finished. I did not know which machine size would be best, so this will give me a good idea.
Other uses are strictly hobby related....like a 1/2 acre vegetable garden with a Big Need of which tiller, plow,etc. etc. to buy and where to buy it.
Any help from garden enthusiasts would be helpful!! I have a front end loader and a 4' brush hog on it now. Tractor develops arouind 16-18 hp. (diesel)
---Don Peak
   / New member near Houston #2
Welcome from Oklahoma. Not to be picky, but your tractor is probably a Zen Noh, not a Ken Noh.
Ken
   / New member near Houston #3
Welcome from NE Arkansas. I have only been a member a short time, and can assure you the information you receive from this group is very helpful. Especially for a non-farm guy like me.
Ken:
Thanks for the corredtion....Zen Noh is what i have. Now, i need to change my profile and dont know how. Nice web site here and very informative!! I'm an Okie and go there a lot to see relatives. Don
   / New member near Houston #5
Don welcome to TBN from down Bay City way. I started with a B7510 which is a 21hp gear driven tractor. Have a FEL (front end loader).
If your garden area has never been used for a garden the soil is going to be compacted. You will need a plow to go down 6 to 10 inches and turn the soil over. I made do with a middle buster from Tractor Supply. Not ideal but what was available at the time. Then you want to go over it with a tiller. Depending on your soil you may want to add soil enrichment or sand to break up clay. Tractor Supply on occasion has tillers for compact and sub-compact tractors. 48" should do nicely. These are typically orange in color. A tiller for a standard size tractor can be some what cumbersome on a compact because it is made for a tractor with a higher ground clearance. Typically gardens are made with raised beds in our area. To make a raised bed I have found a "hiller" or "bedder" to be very useful. This is a tool bar with a pair of disc's attached to a tool bar that fits the 3pt. The discs are set like / \ which pushes the dirt up into a hill or bed. I found that disc's work better than plows.
For "cleanup" I have found that a landscape rake works well. It can be useful in spreading and smoothing sand as well. I have several other attachments as well. However the wife has threatened that the next tractor or implement may come with divorce papers. LOL So take heed!
   / New member near Houston #6
:welcome:
   / New member near Houston #8
Welcome to the forum.
Hey thanks for the garden info from Bay City!! I located and bought some Gilsin implements that i can adapt to my
wider 3 pt. hook-up. blade, plow, two rows of small discs, two cultivator( spines?)s and my neigbor has a wide discs i can borrow. Will probably get a box blade and a bigger discs in the future and sell this nice set of New Gilson attachments.( Only paid $200!) or trade it for a bigger disc. Thanks again for the garden info. ---don
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
2018 JLG 4045R 40FT. Electric Scissor Lift (A51691)
2018 JLG 4045R...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2005 Sterling Acterra Tender Truck (A53472)
2005 Sterling...
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
