- Joined
- Apr 20, 2020
- Messages
- 13
- Location
- Mount Carroll, IL
- Tractor
- Ventrac 4500P, IH Farmall 404, Kubota L3050, Hough H-30, Waldon 5000
Hello All,
First post here, obviously, and just purchased my first Ventrac, a 4500P with 700 hours from a dealer. It is equipped with duals and a tough cut mower. The dealer assured me that the tractor had been completely serviced, and he said that the steering and hydraulic lift noise was normal for a Ventrac. When I got it home, I couldn't adjust the weight transfer. Called the dealer service guys and they said that even the 4500 didn't always pick up the heaviest attachments all the way. Use a jack, which worked. After the first ten hours, though, it would barely raise the mower.
Further investigation revealed that the machine had probably never been greased - that helped the steering slightly, replacing the hydraulic fluid and filters made the steering and lift work perfectly and silently, and draining the black tar from the engine made me feel better about the engine. Unfortunately, the weight transfer still couldn't be adjusted even though the lift cylinder was maxed out. Removed the weight transfer from the tractor and found the shaft bent about 20 degrees right where it enters the big spring. Straightened it in the press, re-installed, and it now works as it should.
I really love this machine as it is perfect for the heavy stuff around the pond and the steep rough ground around it, as well as all the paths in the timber, etc. My only question is: What bent the weight transfer shaft, and should I always set it to zero when not using the mower or when transporting it? Definitely don't want that happening again.
I am happy to have found this site and look forward to learning from the community.
Michael
Michael
