New Owner with three point problem (Rockshaft?)
   / New Owner with three point problem (Rockshaft?) #1
tycham
Caliente, NV
JD 4300
I am in the process of buying a JD 4300. The only know problem is that the three point does not raise. The current owner said that his son was using a gannon box with rippers down. While pulling it, there was a loud noise and now it doesn't work. Any ideas? Is the control valve the most expensive part?
Anyone?
   / New Owner with three point problem (Rockshaft?) #3
There's a number of aluminum castings back there, so do a close visual examination for any broken parts.
As far as internal breakage, I suggest you search for TBN member's dfkrug threads on rebuilding 4300 tractors. They are quite informative and I've learned much from them.
This could be an expensive repair, so investigate first...before you buy the tractor. Good luck!!
Ended up being a clogged filter. Not cheap to fix but not killer either
ECHO SRM-2210 GAS POWERED WEED EATER (A51244)
ECHO SRM-2210 GAS...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
Wolverine Quick Attach Screening Bucket (A50514)
Wolverine Quick...
UNUSED FUTURE MINI SKID STEER MIXING BUCKET (A51244)
UNUSED FUTURE MINI...
2023 LANDHONOR VPC-11-72W VIBRATORY PLATE COMPACTO (A51244)
2023 LANDHONOR...
2011 Chevrolet Malibu Sedan (A50324)
2011 Chevrolet...
