New tie rods
/ New tie rods #1
tractorcrazy
How tight should the nut be on new tie rod ends .they have castle nuts .thanks
/ New tie rods #2
Tight. Use a standard torque chart for the diameter and thread pitch of your rod end and either grade 5 or 8.8 hardness (depending on whether the dimensions are Imperial or Metric) if you don't have a published spec for the specific parts.
/ New tie rods #3
If they use a taper mount, run the nut down to about 20 ft/lbs. then tighten to first available pin hole--Never back off to find hole. Install the cotter pin.
/ New tie rods #4
20 lb/ft could be woefully inadequate on a larger size rod end. Torque needs to be relative to size and sufficient to seat the taper. Striking the side of the receiving socket with a hammer during the tightening process will help with the seating.
2022 THOMPSON PUMP 6X6S1 PORTABLE PUMP (A59823)
2022 THOMPSON PUMP...
Vermeer Vac trailer (A60352)
Vermeer Vac...
2016 Hyundai Sonata Sedan (A59231)
2016 Hyundai...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
John Deere 5525 (A60462)
John Deere 5525...
PREVIEW DATES AND TIMES (A61166)
PREVIEW DATES AND...
