New Tractor Ahead
   / New Tractor Ahead #1
Anonymous Poster
Epic Contributor
Hello Everyone.
We have recently purchased a house on 32 acres in East Tennessee (20 in pasture, the rest steeply wooded), and it seems we need a tractor. /w3tcompact/icons/tongue.gif
I've never purchased a tractor before (lawn tractor aside), so I'm a neophyte at this business, but I've learned a tremendous amount by reading the posts on this board. I now feel fairly confident that I will make the right decision when purchase time comes. In the meantime, however, I hope to learn more by asking a few questions of the knowledgeable folks who post here, so here goes.
1. What's the best way to decide on how wide an implement should be, a box blade for example?
2. I gather that heavier weight implements tend to be of higher quality, and in some cases perform better. True?
3. Lots of people reverse the wheels of their tractors. I plan to do the same. What are the negatives?
4. What brand of FEL do you recommend?
5. Rotary cutters seemed to have two HP ratings: Tractor HP and Gearbox HP. Am I correcting in assuming that gearbox HP is the maximum power that the cutter can handle without grenading itself?
6. Remotes are an option on some makes and standard on others. How important are they, and if springing for them as an option, is it worth it to go to dual remotes?
7. How are tractors titled, or are they? Does a new tractor come with something like a certificate of origin as motor vehicles and trailers do?
8. What's the customary deposit when ordering a tractor? 10%, 20%...?
9. Anyone in the Tennessee Valley care to comment on R1 versus R4 for the hilly conditions around here?
10. My current thinking is a 35hp 4wd tractor with FEL, box blade, bush hog, and auger to start. Work will be pasture clipping, constructing swales, driveway and trail grading, pond maintenance, some fence work, and general dirt moving. Any comments?
Thanks, SnowRidge
   / New Tractor Ahead #2
The NH TC 35D or 40D are nice tractors,
they are on the large frame which gives
a 2000# loader rating.
The box blade should be wider than tires,
this size tractors can go 6' or 7'.
W/ box blade dual remotes can use the top-n-tilt
(2 cylinders that adjust side to sideangle and
front to back level to allow cutting or to cut
swales or ect).
The factory NH loaders are nice and come w/
SSL quik-tach so forks,grapple bucket,or different
buckets can be changed fast.
Most SSL companies make a HPD that will go
on FEL so easier to see what u are doing.
Northern Hyd. has a HPD that bolts onto
bucket also.
Both of the mower HP ratings should be above
the tractor HP, the higher HP mowers are built
stonger and could give more life.
Some tractors have more PTO HP than
others w/ same engine HP (hydro lose more
PTO HP than gear drive) .
Wider tires settings give more stability but
also need wider tools to cover tire tracks.
   / New Tractor Ahead #3
SnowRidge Wecome toTBN:
If you read my reply in the "New To Tractors" thread that I posted earlier today you will get a good veiw of my opinions on buying a compact tractor for an acreage owner. I only have three acres myself but do a lot of commercial mowing, landscape and excavation work for the surrounding area. And I use a New Holland TC29 (midsize frame) equipped with a Woods 1012 loader and a Woods 7500 backhoe. For my operation this is exactly the size I need as it affords better maneauverability than most of the higher horsepower models. Basicly the only limiting factor that I have to deal with is it only has enough pto horsepower (25) to operate a 5ft bushhog and a 6ft would be nice. And it will only power a 5ft rototiller, but that is fine. I also pull a 6ft rear discharge 3pt. finish mower with no problems.
Basicly on implement width I shoot for what extends beyond the width of my rear tires, and the limiting factors of power versus traction. That way my tire tracks are covered up by the pass of the implement. The rear tires on my TC29 are @ 5ft wide, therefore I am running a 6ft boxblade. however if I allow the BB to completely fill with dirt the weight will quickly overcome my ability to apply traction to the ground. If its an implement that angles such as a rear blade or landscape rake I shoot for a size that extends to the outside of my rear tires when at maximum angle. Therefore I am running 7ft rear blade and Landscape rake.
In reguards to implement weight. It definetly helps ground engaging implements dig better, as they cut in, instead of floating over the top of the ground. As for quality thats just common sense.
There has been some talk that reversing your front wheels have caused extra strain on front spindles and bearings. I had an older Kubota that went through two sets in twentytwo years of service. Yes the wheels were reversed. But with the heavy loader work that tractor saw constantly they might have gone out anyway. positive side is more stability and traction.
Most of the manufacturers provide decent loaders badged under their names. And most people seem to purchase the loader designated for that tractor model by the tractor manufacturer. I for one went to an aftermarket loader manufacturer simply because I needed a higher max lifting capacity than New Holland offered. There are some very good aftermarket loaders out there. Woods and Allied/Buehler both make good ones. As well as others. One peice of advice no matter who's loader you purchase, buy a heavy duty bucket for it, and you will probably only have to do it once.
The HP rating designated by the manufacturer of the rotary cutter is the max PTO HP that the gear box is designed to hold up to. While tractors are advertised in gross engine HP, and max HP at the PTO
One set of rear remotes allows you to operate one hydraulic cicuit through its own valve. One set of remotes is nice, two sets even nicer if you are going to have the need to operate two seperate functions at the same time. I for one have one set for the rear and the second set plumbed for operating an extra function off the loader arms, such as angling a snowplow or hydr. auger. They are not cheap, so if you want them I would purchase them at the time of purchase.
Not sure how the tractor is titled ??? wil have to check with the bookkeeper.
Most dealers I know ask for a 10% deposit minimum.
Local dealers can tell you which tires most customers take out the door.
Hope this helps you. I see you already have a good idea of what you need to start out with. Good luck with your new tractor.
   / New Tractor Ahead #4
Rotary cutters hp ratings are:
Tractor HP: The very minimun HP tractor to effectively use the cutter.
Gearbox HP: Yiu said it best. Maximum HP before destruction
Both might be fudged a little, but it sure would be better to stay qithin them. And actually, the number SAYS HP but may also mean Weight. A light weight tractor might get thrown around by the same cutter that a heavier tractor of the same HP can handle effortlessly.
   / New Tractor Ahead #5
<font color=blue>Most SSL companies make a HPD that will go
on FEL so easier to see what u are doing.</font color=blue>
Assuming you have half a clue as to WHAT a HPD is.../w3tcompact/icons/grin.gif
What is it?
   / New Tractor Ahead #6
Snowridge, you've already gotten good answers, but I'll throw my 2 cents worth in (in many cases we're talking about personal preference and opinion, of course, and to a great extent, I'll just be repeating what others have already said):
1. I want implements slightly wider than the overall width of the tractor - outside rear tires, and it greatly simplifies things if all implements are the same width; i.e., the same width as the bucket on the front end loader.
2. Usually true.
3. Be sure to check with the dealer/manufacturer/manual; some tractors are designed to reverse the wheels and some are definitely not.
4. I want the FEL to be the same brand as the tractor; only one dealer/manufacturer to deal with in the unlikely event of a problem, it'll be designed to work with that particular tractor, it will "look" like it belongs there, and resale will likely be better in the future.
5. Tractor HP = minimum you need to use it effectively.
Gearbox HP = maximum you can use without risking damage to the gearbox.
6. Well worth the cost to get the dual remotes; you'll find many uses for them.
7. I think that may depend on your state laws; no title in my state; just a bill of sale.
8. I think 20% is most common, but I also think it just depends on your credit rating.
9. Well, I'm not in the Tennessee Valley (but I've been there); I'd go with R1 for maximum traction unless you have a specific need for another type.
10. Sounds like the right set-up to me, and when you start using that box blade, you'll find hydraulic top 'n tilt to be indispensable, and that's when you'll want those dual remotes.
Beautiful country you're in; good luck with the tractor shopping.
   / New Tractor Ahead #7
I believe that HPD was meant to be PHD (post hole digger). These can be Skidsteer plate mounted with QuikAttach, or mounted on the side of a FEL bucket. The problem with the Skidsteer plate mounting is that it is difficult to see the auger working because the hood of the tractor is in the way. <A target="_blank" HREF=http://www.danuser.com/products/hydraulic_diggers/hydraulic_diggers.htm>Danuser Mfg.</A> suggests that CUTs use the bucket mount (rather than the QuikAttach mount) for that reason.
   / New Tractor Ahead
Hi,
I got a lot of good advice on the tractor title question when I asked:
Should I title my tractor?</font color=blue>
Click the above link for all the details/w3tcompact/icons/smile.gif
Ended up settling for the certificate of origin...
Bill in Pgh, PA
   / New Tractor Ahead #9
WELCOME TO THE FORUM; just tell u to re-read KODIAK"S post he pretty much says it all
   / New Tractor Ahead #10
Answers are interlaced.
Many people choose an impliment that will cover the tracks of the rear wheels.
Generally. For instance, I have seen very light box blades bowed back, when they snagged on a root. ( I'm shure it jolted the heck outta the tractor too! ).
However, remember that the more weight your impliment is, the less weight you have available for payload or pulling ( dirt scoop or trailer ). Though this becomes less important as you move into the mid size tractors with 3pt capacities in the 2k# range.
Also, lotsa weight on the rear may neccisitate some weight on the front to ballance out.
Wider footprint? less maneuverable? I think the benefits much outweight the negatives, unless you are on a size
constraint.
Yes, one is hp ( range ) needed to operate the cutter, the other is the hp it is rated to handle.
Do you plan on running external hydraulic cylinders? If so, the are important.. if not.. then....
Some tractors have a hydraulic manifold for plumbing in external hydraulics at a later time. For instance, my NH 1920 has it, and I have seen many more.
If you don't get the remotes, you may want to at least considder a tractor with this option so you can easilly add the remotes later.
I have heard that in some cities / states you can register a tractor like a car.. but the general consensus is 'no'.
Hafta ask the dealer on that one.. for reference though, I put 10% on mine to hold it till I came back with financing.
Sounds like a nice machine. Though your front end loader will probably do the largest share o f the work,, we 'loader-less' people get lotsa work from a boxblade.. very usefull impliment, probably a close 2nd to the loader for general purpose work.
Good luck!
Soundguy
5 Shank Inline Ripper (A50514)
5 Shank Inline...
2018 INTERNATIONAL 4300 BOX TRUCK (A51222)
2018 INTERNATIONAL...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2014 FREIGHTLINER M2 DAY CAB (A51222)
2014 FREIGHTLINER...
2016 PETERBILT 587 (A50854)
2016 PETERBILT 587...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
