New Tractor
   / New Tractor #1
1Lawman
Joaquin, TX
2012 John Deere 5093E
Buying either a John Deere 5060E with cab or Kubota MX5400 with cab..Will be used primarily for heavy shredding with 6' or 7' cutter. Will not get a lot of use..Suggestions??? Thanks!
   / New Tractor #2
Whichever tractor, build a heavy duty expanded metal rear window protector. Trust me, you'll not regret it.
   / New Tractor #3
T-B-N ARCHIVE:
   / New Tractor #4
I thought the MX was kinda like a large L series. Smaller than a M tractor. Just like a BX is smaller than a B series. Not sure those two tractors are really even comparison in weight and capability.
I would compare the larger L series Kubotas to the 4000 series JD. I always thought that a true M series Kubota would be comparable to a 5000 series JD.
   / New Tractor
   / New Tractor
The John Deere has no regen and the Kubota has regen but no DEF..Is that a consideration?
   / New Tractor #7
Like all the X series Kubotas, the MX is sized to be a crossover between the M and L series, so in-between.
   / New Tractor #9
Or get a chain guard kit for the mower. Haven’t had anything kick up enough to damage back of cab.
   / New Tractor #10
Looks to me like the JD is about 10 HP more and 2500 pounds more. Quite a difference really.
THIS ^^^
That much weight creates a huge gain in traction. Frame strength/durability will be better.
Case IH 455 Round Baler (A46877)
Case IH 455 Round...
2007 Chrysler Aspen (MPV), VIN # 1A8HW582X7F516547 (A44391)
2007 Chrysler...
Mi-T-M Trailer Mounted Hot Water Pressure Washer (A44571)
Mi-T-M Trailer...
John Deere 9520T Tractor (A46878)
John Deere 9520T...
Volvo SD-100D Single Drum Vibratory Dirt Compactor (A44571)
Volvo SD-100D...
2014 International DuraStar 4300 Klein 2,500 Gallon Water Truck (A44571)
2014 International...
