Newbie 3pt. Question
   / Newbie 3pt. Question #1
DIYGuy
Central Massachusetts
Jinma 224
How tight should the sway turbuckles be on the 3pt. arms? The reason I ask is that I assumed that the rotation of the 3pt. lift arm shouldn't have any bearing on the tightness of that linkage, however, I had mine in the upper position the other day and I tightened them to reduce the sway on an implement. When I lowered the implement, I heard a loud pop and found the end of one turbuckle had broken. I looked at this for sometime and figured out that the lover pivot arms are 1/4" lower than the pivots of the turnbuckle linkage, so it will get a loose when raising and implement and tight when lowered. So by tighening the links in the up position I removed the necessary slack and when lowering the implement, something had to give.
Is this normal?
MarkS (DIYGuy)
   / Newbie 3pt. Question #2
Yep. That's the way mine is.
   / Newbie 3pt. Question #3
Thanks for the story so we can learn. I saw the delivery guy tighten up mine while the RFM was on the ground and he put the slack in the upper fork, so I just assumed this was the way you did it. He did tell me to keep the upper slackened, but didn't mention anything else - I am sure mine would do the same as yours. Bota 7800.
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
6x14 Double Axle Bumper Pull Trailer (A51572)
6x14 Double Axle...
11ft S/A Fuel Tank Trailer Frame (A51691)
11ft S/A Fuel Tank...
2024 New Holland T8.410 MFWD Tractor (A52748)
2024 New Holland...
2013 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2013 JACK COUNTY...
