First, Welcome to TBN
Yes, both are Diesel engines. It has to do with the way the fuel is injected into the cylinders. Here is some text I copied from another SITE:
"Direct Injection (DI) vs. Indirect Injection (IDI). Most heavy vehicles today use direct injection (DI) diesel engines,
while until recently most automobile-size diesel engines have used indirect injection (IDI) technology. DI
engines inject fuel and air directly into the cylinder, while an IDI engine uses a prechamber to help mix the fuel
and air before entering the main cylinder. The IDI system comes with a 15 percent efficiency penalty compared to
the DI because the prechamber permits additional energy losses (Ashley 1997; Arcoumainis and Schindler 1997),
but its superior fuel and air mixing has been essential for diesel passenger vehicles. The small, high-speed engines
used in automobiles require fuel and air to mix 10 times faster than in larger engines (Heywood 1988), something
that has been difficult to achieve without a prechamber. Only recently have diesel engine developers overcome
this mixing limitation with DI engines."
In a nutshell, the DI engines are more efficient, start easier, and cost more!
Hope this helps...
