willr524
I am a very happy owner of a new BX1850 w/ a LA203 FEL on it. I know that it is small by tractor standards but it is all my property needs and does mostly lawn mowing duty.
I wanted to make sure that I am maintaining everything properly and since the loader has about 11 hours on it, I wanted to make sure that I lubricate it properly. The manual indicates greasing the joints on the FEL which I understand but I also mentions the grease fittings. The only fittings I could find were at the ends of the three hydraulic cylinders on the loader.
So I have to questions:
1) Those are grease fittings right? I am new to hydraulics and I wanted to make sure that they aren't hydraulic bleed valves or something like that?
2) Am I missing any other fittings? Everything else looks like you just lube the pins at the joints.
I saw someone's post about making sure the fitting is clean before lubing it so I don't force direct back into the fitting. I bought the right grease (HP stuff from Kubota) at the dealer. Any other tips or tricks that aren't in the manual.
Thanks for you help on this one.
