Newholland 1320 question
   / Newholland 1320 question #1
Blue Sky Retrievers
Hi guys I'm not really a tractor guy but I sure could use some help. I was told this is the place to get it.
I borrowed my brothers tractor, was using it to push over some brush. I was trying to lift out a bush with the bucket when the tractor stalled and now it won't start. It acts like I hit a kill switch. Checked tyhe PTO and other switches / knobs and everything seems in place. Any idea's before I call out a mechanic?
   / Newholland 1320 question #2
does the engine turn over?
No, Like I said it acts like a kill switch. The light in the dash comes on but no starter. It doesn't crank.
   / Newholland 1320 question #4
Check fuel level,then wiring to the shutoff solenoid,maybe a branch pulled the wiring off....I have had branches pull the starter triger wire off my 1910,the next time i go to start it,its dead,then i see the little wire off the starter..plug it back in and im good til next time.
Third times a charm, I crawled underneath for the third time determined to check every square inch. Found it! Sensor wire was disconnected. Plugged it back together and it fired right up.
Thanks for the help. Now I can only retrurn the favor with what I know, retrievers, firefighting and some plumbing. Feel free to pm me.
Jim
   / Newholland 1320 question #6
Glad you got it,the 20 series are great tractors,not much goes wrong with them.
   / Newholland 1320 question #7
Jim
veri common on the 1320. it's just in the wrong spot. when i had mine i was so sick of crawling under it i tape the thing together. never happened again
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
2002 MANAC 48'  WALKING FLOOR REFUSE TRAILER (A53426)
2002 MANAC 48'...
2018 Chevrolet Silverado 2500HD Knapheide Service Truck (A51692)
2018 Chevrolet...
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB Crane Mechanics Truck (A52377)
2015 Ford F-350...
