NH 275 square baler
   / NH 275 square baler #1
Pusto
Lavaca County, Texas
New Holland 3930
The pickup drive chain on this old 275 square baler jumped the sprocket when I drove it into an armadillo hole, and then it stripped some of the teeth off of the sprocket. The chain was very loose to begin with, and now it seems even longer. Is replacing the sprocket a big deal? What about the chain? Should it
be shortened a link? Thanks for the help.
   / NH 275 square baler #2
Replace the chain, while the sprocket is done. Chain is cheap insurance for getting hay up when the sun is shining. A busted baler chain when rain is coming is no economy.
I'm gonna buy a couple of boxes of chain for my baler. This Spring when everybody was baling and busting chain, the local dealer stock was cleaned out. We had to drive quite a distance for chain on a buddy's baler. That was two hours, we could have been baling instead of riding.
   / NH 275 square baler #3
as said replace the sproket an chain at the sametime.im betting that the chain is streached an pretty loose.
   / NH 275 square baler #4
Do you have the cast gear with the long teeth or the steel one that has double the teeth? Depending on which one you have the chain you use differs.
PUMP JACK (A48992)
PUMP JACK (A48992)
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
Wolverine Hydraulic Tiller Skid Steer Mount (A47371)
Wolverine...
2011 SOUTHWEST  GOOSENECK (A48992)
2011 SOUTHWEST...
2019 KENWORTH T880(INOPERABLE) (A48992)
2019 KENWORTH...
2022 Club Car...
