NH 488 Haybine reel drive chain?
   / NH 488 Haybine reel drive chain? #1
Tx Jim
New Member
Coyote Flats,Tx
JD 4255/Kubota M7040 HDC
I'm trying to help a neighbor. Is there a method to tighten reel drive chain without utilizing an offset link to remove a link from chain??
Thanks,Jim
   / NH 488 Haybine reel drive chain? #2
I thought that all of the reels were belt driven?
Yes there's a belt that powers reel BUT there's a chain that powers the belt. here's the chain(key 2) I'm referring to.
   / NH 488 Haybine reel drive chain? #4
Yes,
You need to be under the haybine behind the rollers. Up high there are two small bolts (1/2"?) that you loosen then there is a sliding adjuster that you tighten. I'm not home or I'd take a picture.
Standing behind the haybine the adjuster is on the right side.
The picture you have above looks like the most upper piece to the right is where the two holding bolts are. That plate is on the chute of the haybine.
cat fever
Thanks for reply. I give info to my neighbor.
Jim
   / NH 488 Haybine reel drive chain? #6
hhmm interesting. Thanks for the pic.
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A52577)
2016 WESTERN STAR...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2002 Fleetwood Expedition 36ft Class A Motorhome (A51694)
2002 Fleetwood...
INOP/NON-RUNNING 1999 International F-2574 Fuel Lube Truck, VIN # 1HTGGATT4XH682675 (A51572)
INOP/NON-RUNNING...
2009 VOLVO VNM DAY CAB (A52576)
2009 VOLVO VNM DAY...
