NH TC29 power steering problem
   / NH TC29 power steering problem #1
RoyK
Bronze Member
North Central PA
NH TC29D
I had to remove the power steering pipe from the pump to the steering wheel to have it reflanged. No problem. I topped off my power steering fluid and the steering works but is sloppy and can be difficult to turn. It's usable, but annoying and hard to maintain a straight line or a smooth turn when mowing. I rechecked the fluid level and it is fine. I figured I have air in the system and it'll work it's way out on it's own. Well, it's been weeks now and I still have the problem. Is there some process to bleed the lines?
   / NH TC29 power steering problem #2
Using the FEL, raise the front axle off the ground. Turn the steering wheel lock-to lock slowly several times. Check the oil level again. If it doesn't steer well then, you have other problems.
Thanks! I'll try that as soon as I get a chance to put FEL back on.
Thanks RickB! I jacked it up and did as you said. Much better! Not perfect, but much better! I'll repeat the procedure tomorrow.
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2015 Toro Z Master Professional 64in Zero Turn Commercial Mower (A50322)
2015 Toro Z Master...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A52748)
JOHN DEERE ROW...
