NH TL90A Transmission pressure light??? How do I fix
   / NH TL90A Transmission pressure light??? How do I fix #1
Tdunham
New Holland TL90A
It is a 2008 New Holland TL90A and the STOP light came on and it shows to be Transmission pressure according to owners manual. Its the weekend and this needs fixed, I have a lot of automotive repair experience and this baffles me.. PLEASE help..
   / NH TL90A Transmission pressure light??? How do I fix #2
Did you go around a right hand corner quite fast ? The sensors on the top left hand side of the transmission give trouble . When taking a right hand corner on a road to quick , the oil in the trans gets into the sensors and bridges the contacts and puts the light on .
..............This may not be the cause but it is quite likely .............
Also a stick can pull off the wire terminals underneath , get under and look at the sensors on the left side of the trans to see if this is the case .
Will these sensors be easy to locate???
   / NH TL90A Transmission pressure light??? How do I fix #4
There's 3 on the top left hand rear of the trans , pull out the washer bottle to see them with a torch . You may be lucky and see that one is wet with oil .
The lower left ones are easy to see from the bottom , they look a little like oil pressure senders on an engine .
2015 Kia Sedona Van (A50324)
2015 Kia Sedona...
2016 Toro Pro Force Towable Blower (A50322)
2016 Toro Pro...
2000 Ford Ambulance (A47384)
2000 Ford...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
2018 CATERPILLAR 336FL EXCAVATOR (A52141)
2018 CATERPILLAR...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
