Nimco FEL joystick valve diagram and relief valve? And rear remotes?
   / Nimco FEL joystick valve diagram and relief valve? And rear remotes? #1
DiskDoctr
Platinum Member
Western PA
Mahindra 3510
I've searched but can't find this info. I am looking for a diagram of the Nimco joystick valve used on the FEL of my 2004 3510 (Shuttle shift).
I have read it has an adjustable relief and it already has the PB plumbed to the included rear remote.
I want to check then adjust the relief, and add to the rear remote for TnT. I have the hydraulic toplink from CCM some years back and would like to add tilt.
If there is a post on how to adjust the relief (where/how), I didn't find it.
I may add a hydraulic angle for a back blade and york rake in the near future. Maybe go with a 3 position selector off the existing remotes and use the in-built lever for controlling? I can live with adjusting one at a time.
Thanks!
- JC
   / Nimco FEL joystick valve diagram and relief valve? And rear remotes? #2
#4 is the relief
Not sure if this is your valve or not..
Thanks for the reply. I believe the valve is Nimco 10339-2S
Here is a pic I posted in another post
How do I adjust the relief? Tighten the (jamb nut?) I can't tell from the image if it is a nut or a screw.
And where would you suggest I put a gauge while adjusting?
Sorry so many questions. I have used equipment with hydraulics for 30 years, but don't normally do more on the hydraulics than change filters, fluids, hoses, and occasionally a pump :) I understand the principles, but am new to the internals used.
I feel stupid even asking :eek:
   / Nimco FEL joystick valve diagram and relief valve? And rear remotes? #4
If I remember right you have the one that is none adjustable.
I thinking.......
I thinking.......
That would be bad news. Would some additional pics help?
From what I (thought) I read in other posts, I thought this one was adjustable and the Prince was not. But there seems to be some questions about it- one of the reasons I was hoping someone has the diagram and/or info :)
If it isn't adjustable, then I would have to adjust it on the tractor, right? Again, this is all from other posts.
- JC
Sorry, I was wrong about the model Number. It is 10373-2s. See the pics for part nums, left side and top views. They are from my cell, so not the best.
   / Nimco FEL joystick valve diagram and relief valve? And rear remotes? #7
Why do you think you need to increase your working pressure? As far as checking your pressure, you can check it at the rear remotes or one of the loader ports. The pressure relief on your valve is the hex that shows in your middle picture, but it isn't adjustable. The tractor pressure can be increased but it should be checked first to see if it is indeed below specs and it is no simple job, as the adjustment is internal.
Galen,
The FEL feels under powered and sluggish. I've asked a few Q's in the past, but now am going to get into figuring it out. This week I followed another's advice and reseated the screw holding the spring on the bottom of the up/down valve.
I am also shortly to be adding a tilt to compliment my hydraulic top link, possibly an additional set of ports to angle a back blade and york rake.
I am looking hard at a QA for the FEL, too.
In short, this is the year to get some equipment geared up for use. Been using it some, but expect to increase a bunch this year. I want to get everything in optimum working condition.
This past summer the mechanical part of the FEL valve ("ball mounts") rusted and popped out while on a job. I didn't realize water was getting in through the boot. Makes sense now, but didn't think about it before. I fixed it.
I'm not thrilled with the movement of this joystick. Straight forward and back for up/down is okay, but more like 10 o'clock and 4 o'clock for bucket roll. I don't know if this was normal before and it just started to bother me or if the valve needs work. I've been running the Case 580K TLB and JD 455D loader/backhoe a fair amount.
I picked up another brush hog and bigger york rake this fall, too. We resurrected a back blade in this snow storm.
I have considered replacing this valve, but money is tight. I figured if I worked on getting the front hydraulics operating at peak performance, I could either work on or repair the valve (whatever it takes), or replace it if it was still unsatisfactory.
The curl/dump is very slow. I had even asked before about upgrading the pump to a higher volume one, but the replies weren't very supportive of that idea (helpful, but didn't seem to think it was a good idea)
Don't get me wrong. Out of a bunch of equipment we have and others I run, my 3510 is my favorite :D It was the first NEW piece of equipment I bought. I've always bought others' leftovers. Guess that's just my lot in life. No complaints ;)
So there's a long story about it. It's okay, but could and I think should be better.
And IMHO, there isn't a more helpful and more knowledgeable group to ask. I've been away from the site for a while, was spending time working away from home and had some medical issues.
I am really anxious to get this in tip top shape. Have almost 40 hrs on her in the past 2 weeks with the snow.
Thanks everyone for taking the time to help out. It's really appreciated!
- JC
Well, I think I found the problems with the FEL joystick valve.
It is all mechanical.
There are three pivot points in this Nimco joystick. Two on the Right side and one on the Left.
The Up/Down spool is on the Right, the curl/dump spool is on the left.
Essentially, the left pivot ball is for up/down and the top right is for curl/dump. The third one on the bottom right is a fixed pivot point for both motions.
It is the fixed point that is the problem. It is designed so the ball fits into a socket that is a tapered slot from top to bottom. Apparently, you are supposed to insert the ball into the top portion of the slot and it isn't supposed to be able to slide out the bottom of the slot.
Mine had a bunch of rust and junk in it this summer (I didn't know the rubber boot leaked) and it was rough working for a while. This seems to have contributed at least in part to the problem.
The third ball is worn out of round and the slot taper appears a bit deformed. This allows the joystick housing (a single piece that houses all the ball sockets and the joystick handle threads into) to lift up instead of being a fixed point when curling the bucket.
Without being a fixed pivot point, when curling the bucket, the joystick also pulls up slightly on the up/down spool. This leads to unwanted raising action much of the time while curling, AND WEAKENS AND SLOWS THE CURL action (splitting flow to both spools).
Tonight I consciously pushed down on the joystick while moving it directly to 9 o'clock position and it worked great with good power. If I don't push down, I have to push to about 10 or 11 o'clock to get curl and then it is weak as described above.
I also found the trick to inserting the balls into the sockets. I'll post those in another post when I get some pics. Sorry, didn't have my cellphone with me on the tractor tonight.
I've posted in Hydraulics to see if anyone has a broken Nimco Joystick Valve for the FEL. If so, perhaps I can replace my worn mechanical parts.
The main part with all the sockets appears to be cast? (anyone know for sure?)
Thanks!
- JC
   / Nimco FEL joystick valve diagram and relief valve? And rear remotes? #10
I believe that the you are correct about the socket part being cast. I believe I stock the balls as some have had problems with them, but I don't believe I have ever sold the socket part.
How much are the balls? I've kicked around the idea of adding weld and then grinding to shape, but if they are reasonable cost... Can you PM me the cost of the fixed one?
If the ball is the right dimension, perhaps the fitment won't be so sloppy :)
I'm also considering checking with a machinist buddy of mine to make a new "block." I'd rather find a replacement than go through all the setup and perhaps he doesn't have the right size tool...
Thanks!
- JC
I have been pondering the situation with the "block" piece...
If I can't find one, I may be able to machine an insert to cover the bottom of the tapered slot and drill/tap for some allen screws to hold it in place. That should allow me to tighten it when installed.
I did a test last night. I clipped a small pair of vise grips on the bottom of the block so that it would hold the ball in the slot. The joystick worked very well.
If I can get a pivot post and make this insert, I may be in business. I'm still hoping someone responds to my request for the mechanical valve parts, though :D
- JC
If I were you, I'd go directly to NIMCO Nimco Controls
Yeah, I emailed them over the weekend. Hope for a reply. Galen is also checking on something for me, too.
Thanks for the suggestion and the site!
- JC
These "ball studs" (proper non-hydraulic industry term) wouldn't happen to be standard 10mm would they?
If so, maybe a stainless steel replacement would be better to avoid future rust issues?
- JC
Okay, as far as I can tell from measurements while on the machine, it is a 13mm ball stud. The closest stainless one I have found is this one at suspa.com
I don't have a price or availability yet...
I finally got a reply from Nimco. The info was quite helpful, so I am posting it here for others to reference.
Attached is a drawing of the 10373-2S.
It is CV112 power beyond unit.
This is an older version of our valve configuration.
There is no relief valve in this unit. Reference # 5 is a solid plug that would accommodate a MRV.
There is an option for RV is this valve. The only option is fixed RV.
Currently the only RV we have available are.
10900-4K-140 set @ 140bar - 2030 psi
10900-4K-150 set @ 150bar - 2175 psi
You will need to contact one of our dealers or Mahindra for parts.
I have a PDF drawing of the valve now. If anyone needs it, let me know.
Since there isn't a relief valve, where would it be on the tractor?
I have requested a drawing that includes the mechanical portion of the valve, too.
Thanks!
- JC
Nimco redesigned their joystick to add a pin to the socket to hold the ball in place (actually for all three balls).
In the attached picture, you can see the orange highlights are the pieces concerned. I need the orange ball stud (13mm, 5/16" thread, 1.54" overall, .75" thread length). Considering a stainless steel to prevent rust.
The darkened gray is the back part of the overall housing for all the sockets for the balls. Just under (backside that you can't see) is the tapered slot where the ball stud fits.
Hope this diagram helps someone else, too.
Edit: Here are the parts I need.
Item #8, "Ball Screw, 1409-3052"
Item #12, "Left H. Joint, 1409-3054"
- JC
Bush Hog Rotary Brush Cutter (A59228)
Bush Hog Rotary...
2016 CATERPILLAR 349FL EXCAVATOR (A60429)
2016 CATERPILLAR...
2012 Dodge Avenger Sedan (A59231)
2012 Dodge Avenger...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
2012 FORD F-350 XL SUPER DUTY CREW CAB SERVICE TRK (A60430)
2012 FORD F-350 XL...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
