NO BRAKES ON 2015 KUBOTA S3300HST
   / NO BRAKES ON 2015 KUBOTA S3300HST #1
BIG BAMBINO
SWAN LAKE, NEW YORK
2015 KUBOTA B3300SU
Just became acquainted with your board and decided to join in.As the title states, I have a 2015 Kubota s3300hst that has no brakes. I've checked the linkage back to the differential and seem to be working on both sides. Nothing in Manuel to look for answers, so hoping:confused: someone here can point me in the right direction, Thanks.
   / NO BRAKES ON 2015 KUBOTA S3300HST #2
How many hours does it have?
The reason I ask is it is not uncommon to accidentally drive around with the brakes set...
It happens more than one would think as the engine can overcome the brakes.
The brakes on the tractors I have are more like a parking brake... not something used to slow or stop the tractor... more to hold in place when stopped.
Welcome to TBN
Maybe about 105? I should have added that the pedals are fall all the way to the floor with no resistance at all. I grab a hold of both and move it like a banana skin.
   / NO BRAKES ON 2015 KUBOTA S3300HST #4
Have a look under your tractor, where the brake pedal goes thru the floorpan.
Sounds like your linkage has separated between the pedal and the brakes.
As far as I know, tractor brakes are drum type mechanical brakes. You should be able to find where something under the pan has seperated.
   / NO BRAKES ON 2015 KUBOTA S3300HST #5
Double post.
   / NO BRAKES ON 2015 KUBOTA S3300HST #6
Wondering if the OP got a chance to check things out, and what he found.
   / NO BRAKES ON 2015 KUBOTA S3300HST #7
Modern tractors use multi-plate wet clutches for brakes, and they are extremely reliable. For
BOTH L and R to not work, I would think that the problem is where the 2 linkages come together.
   / NO BRAKES ON 2015 KUBOTA S3300HST #8
2015??? let the dealer deal with it... :2cents:
   / NO BRAKES ON 2015 KUBOTA S3300HST #9
Best answer yet and I'm ashamed it did not register with me.
2025 CFG Industrial H15R (A50123)
2025 CFG...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
PALLET OF JACKS AND STANDS (A53843)
PALLET OF JACKS...
Yale 3,500lb Electric Forklift (A51691)
Yale 3,500lb...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2025 CFG...
