Oil & Fuel No fuel through injectors, funny noise from pump
   / No fuel through injectors, funny noise from pump #1
Jerry4
Sacramento, CA
Kubota L245DT
My tractor no longer runs. It will start but die. I took the injector lines loose at the top of the fuel pump and there is no pumping going on. What is the usual cause? I unhooked the supply for the fuel at the banjo and fuel runs through the line.
Do these mechanical pumps just stop?
This is on a L246 DT .
thanks
Jerry /forums/images/graemlins/frown.gif
   / No fuel through injectors, funny noise from pump #2
Replace the fuel filter and then bleed all the air out of the lines to reprime the pump, it makes funny noises with no fuel in it since the fuel helps to lubricate the pump.
Thanks, that is the cheap first test. I have never had a filter clog on me before. The fuel will drain in you lower the hose, but maybe it needs more free flow to get enought to the pump.
We have been building a retaining wall and when the tractor quit, I had to switch to a wheelbarrel. Not a good switch!
Jerry
Dead Kubota
   / No fuel through injectors, funny noise from pump #4
"We have been building a retaining wall and when the tractor quit, I had to switch to a wheelbarrel. Not a good switch!"
Your just approaching it wrong. Carry the blocks by hand without gloves for a day. The next day, throw in some gloves and then maybe the wheelbarrow. You will appreciate the wheelbarrow much more. Of course the most logical thing is to get the tractor fixed as soon as possible. /forums/images/graemlins/grin.gif
2015 Timpte Hopper Bottom (A50514)
2015 Timpte Hopper...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
2004 HYUNDAI V12530152-AJS 53FT DRY VAN TRAILER (A52141)
2004 HYUNDAI...
2015 CATERPILLAR 289D SKID STEER (A51242)
2015 CATERPILLAR...
2008 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51242)
2008 CATERPILLAR...
Land Honor 3 pt Disk (A50514)
Land Honor 3 pt...
