No second gear
   / No second gear #1
Adventuris
Tym
Was using my yt359c today and second gear stopped working , first and third still work fine anyone have any ideas
   / No second gear #2
Since your YT359C is a newer model, this definitely comes under the Yanmar powertrain 10yr warranty!
   / No second gear #3
I would begin with the range position switch. To check it turn the key off, hold the display button and turn the key back on. A screen will appear that says "Checker", release the display button. Press and hold the display button again. The next screen will appear saying "Switch, Meter, T/M", press and release the display button to toggle over to "T/M". Once there, you should be able to test the range position sensors. If the voltage doesn't change between shifts, you may need a new switch. Most likely a warranty issue.
24in Tractor Backhoe Bucket BT4555 (A51039)
24in Tractor...
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
2011 MAGNUM PRODUCTS LIGHT TOWER/WATER TANK TRAILER (A50854)
2011 MAGNUM...
IH Cub Lo-Boy 154 (A50514)
IH Cub Lo-Boy 154...
(3) 40 RIG MATS (A50854)
(3) 40 RIG MATS...
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
