No timming mark on flywheel 1954 Ford NAA
   / No timming mark on flywheel 1954 Ford NAA #1
RDKG2
Mancelona,Mi
54 NAA
Installed new oil pump .. repaired distributor. Cannot find timing marks on flywheel to install distributor at the right crank position tried just do it by #1 piston still no luck...Have gas and spark wont start..even have oil pressure. Where are the timing marks ...worn off??? Any help would be great
   / No timming mark on flywheel 1954 Ford NAA #2
Put a flash light shining on the hole, wipe off the flywheel that is showing, use a screw driver (or similar) to move the flywheel and keep wiping...they will show up eventually. that's how i found mine.
I did that until I rotated the fly wheel 360 . Finely I just dropped in the distributor where I thought it should go, it fired up and I moved the distributor back and forth and gave it gas and at any distributor position and rpm there where no marks on the flywheel with using the timeing light. I did have what looked like a mark made by a scewdriver on the edge of the flywheel and went with that. The tractor is running better then it has in years,now the only thing that is wrong is I must not have tightened up the oil pump bolts enough or needed to use a thread sealent because I have oil dropping from the bolts. I will have to wait until spring at this point to drop the pan and either thighten them up or replace the bolts
   / No timming mark on flywheel 1954 Ford NAA #4
Glad you have it running good. I just rebuilt a 54 naa and had the same issue. no marks on the fly wheel so i always time by ear when i replace my points.
HITACHI ZAXIS 250LC-6N EXCAVATOR (A51246)
HITACHI ZAXIS...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A53472)
John Deere 6105E...
2017 Currahee Trailers Trailer, VIN # 4TEFS1826H1034878 (A51572)
2017 Currahee...
Sky Trak 10054 Legacy 10K Telehandler (A51573)
Sky Trak 10054...
