Backhoe Noisey 2365 backhoe
   / Noisey 2365 backhoe #1
cptdave
Bronze Member
New Hampshire
Kioti CK-20,Wheelhorse 4-14-8
When I curl and uncurl the backhoe bucket the top cylinder makes a noise similiar to an air leak or a hiss. Seems to work ok.
Any thoughts?
Dave
   / Noisey 2365 backhoe #2
Extend the cylinder. Then take a straight edge and lay it on the shaft. It sounds like the shaft maybe bent slightly. If it is bent, the seal can make a strange sound as the shaft goes in and out. Given the sound, that is at least one thing that I would check.l
   / Noisey 2365 backhoe #3
Has it always made the noise, or is it new? Does it do it consistently, intermittently? If you're sure that's where the sound is coming from, and not from the front panel connections, Jerry may have it right on, or if not bent rod, at least a leaky cylinder.
Make sure the connections in the front panel below the BH controls are all hooked up tightly and not leaking. I could easily believe the sound could come from there, but is bouncing back to you off the boom. Just a thought. John
Thanks for the replies. The noise seems to have gotten louder.
I only have 2 hours on the hoe and 11 on the tractor.
I will investigate and let you all know.
Thanks,Dave
20Yd Roll-Off Container Dumpster (A49346)
20Yd Roll-Off...
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
Club Car (A50324)
Club Car (A50324)
1985 Big D Pintle Hitch Trailer (A50514)
1985 Big D Pintle...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
John Deere Quick Attach Pallet Forks (A50514)
John Deere Quick...
