Nortrac 204-C draining front Axel ?
   / Nortrac 204-C draining front Axel ? #1
Frankm
Erie Pa
Nortrac 204
there are 3 veary small plugs it looks like to drain the Axel , should i heet them to get them out , there wanting to round off , and wont move , why in the world did they make them so small , i dont want to brake them off , and what size are there , what should i use to get them out ,Thanks Frank From Near Erie Pa .
   / Nortrac 204-C draining front Axel ? #2
You got the right plugs. I had to spay mine for 24 hours with penetrating oil then tap them with a hammer. I used a small crescent wrench so I did not put too much torque on them. If rounding try using a pair of vise grips super tight then clean up the heads once out with a file.
Chris
   / Nortrac 204-C draining front Axel ? #3
Another thing to try if the heads are well rounded off and un-wrenchable (is that a word?)
You can weld a dowel pin or something to the head and use a wrench or pliers to grip on that. The heat from the weld should also loosen the plug.
   / Nortrac 204-C draining front Axel ? #4
If I am remembering correctly I found that an (1/4")extension for a rachet worked best used the female end over the nut and put crescent wrench on end of socket extension. Of course I figured that out after rounding one off -Ed
   / Nortrac 204-C draining front Axel ? #5
Great tip RED. I have also thought of fitting a nut on the square portion then welding it on so I can use a socket for future re-movement.
Chris
   / Nortrac 204-C draining front Axel ? #6
Yeah, that's a great tip Red!
I never thought of doing that. Luckily my plugs are still square so I'll use your tip nest time.
   / Nortrac 204-C draining front Axel ? #7
Why not just use 8-point sockets, which are made for square plugs? Or are the Chinese ones an oddball size? I haven't yet pulled mine out so I don't know.
So much to learn, so little time left to learn it!
Rich
   / Nortrac 204-C draining front Axel ? #8
Rich -basically came down to using what I had available at the time. I did have sockets that fit but they slipped And your right about oddball size the 1/4 socket extension ended up being the tightest. I have metric wrenches but none of them fit -Ed
   / Nortrac 204-C draining front Axel ? #9
I actually have a set of four differend size square drive sockets specifically made for square drive pipe plugs. I think Snap On still carries them.
   / Nortrac 204-C draining front Axel ? #10
I have a small handful of square pipe plug sockets, all 8-point configuration. My experience so far is that my old American 8-point osckets seem to fit all the square plugs I've encountered on otherwise metric vehicles, bu tI have no idea if this means anything or not. The metric vehicles were all cars or trucks sold in the US and not true "foreign" vehicles.
2021 Allmand Bros Maxi-Lite II Towable Light Tower (A52377)
2021 Allmand Bros...
2014 KENWORTH T800 (A53843)
2014 KENWORTH T800...
2022 JOHN DEERE 331G LOT NUMBER 96 (A53084)
2022 JOHN DEERE...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2014 CATERPILLAR 336EL EXCAVATOR (A52705)
2014 CATERPILLAR...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
