Not having any luck locating 10 foot t posts at reasonable price
   / Not having any luck locating 10 foot t posts at reasonable price #2
I did a search typing in ten foot metal t-posts and came up with plenty of hits. The more you buy the cheaper but Agri-Supply came up on top with painted. 8.45 per if you purchase 25 or more posts.
I saw some that were listed as supporting 1.33 pounds per foot and the ones from agri-supply which supported weight of 1.25. Is there any appreciable difference?
   / Not having any luck locating 10 foot t posts at reasonable price #4
What are the posts for?
   / Not having any luck locating 10 foot t posts at reasonable price #5
I think you mis-read that. They don't support that much weight, but rather that's what the post weighs. A 1.33 lb/ft 10' long post will weigh 13.3 lb. A 1.25 lb/ft post will weigh 12.5 lb. That's just a measure of how thick the post is; heavier/lighter construction. For your deer fence, I think the 1.25 will do fine, but they will bend easier too. Unless you are in really rocky soil, you should not have to worry about that.
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
TRUCKING INFO (A50775)
Quick Attach Stump Grinder (A50514)
Quick Attach Stump...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
