Not working fuel gage
   / Not working fuel gage #1
Badasssapper67
OR
none yet
I have a T400 and the gas guage doesnt work. I see that on web this is common, does anyone know what causes it and is it an easy fix?
I dont see fuel guage sending units for sale on ebay so I hope that's not the problem.
Technically I should check the fuel everday before start up but I dont like to get the tank down below half and some of my property is remote.
   / Not working fuel gage #3
First thing to check would be if it was the gauge, disconnect the wire from the sender and ground it, the gauge should move to full, or at least show a change. Check the sender terminal to ground with a DMM, there should be some kind of resistance there. If it shows open, the rheostat is defective.
If you can't find a replacement, it would probably be possible to find one with the same ohm range that your gauge needs and modify it to the round plate that fastens to the tank, but there could be a fair bit of innovative fabrication work involved.
Thanks flyerdan, Im right up I5 from you. I will do those things as soon as I can make time for it.
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A52748)
FIRESTONE 9.5L-15...
2024 JOHN DEERE 8RX310 LOT NUMBER 77 (A53084)
2024 JOHN DEERE...
New/Unused 10ft 40 Drawer Workbench (A51573)
New/Unused 10ft 40...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR29J160609 (A51572)
2009 International...
FRONTIER SA21G LOT NUMBER 145 (A53084)
FRONTIER SA21G LOT...
2013 Kia Soul Hatchback (A51694)
2013 Kia Soul...
