Novice in need of help.
   / Novice in need of help. #1
sdoubledub
Gaylord
Mahindra 2555 HSTC, old Kubota and ancient ford
I just purchased an early Kubota L4200 and found out I cannot add a mid-pto to it. Then I heard about a front pto kit from kubota- FP72-A. Does anyone know if they can be installed on a L4200, or done it themselves? I'm trying to set up a front mount snow blower. Thanks in advance for your help.
   / Novice in need of help. #2
Don't know about the front pto, but there are front mount snow throwers that run off the rear PTO. They have a gearbox and shaft that runs under the tractor. If you search the forum you'll find references to them.
   / Novice in need of help. #3
Like Beez said. They have setups that run off the rear pto with a bunch of gears and a shaft that runs the whole length of the tractor so you can runa front mounted blower. Pretty complicated set up but not craning your neck all the times a big advantage.
   / Novice in need of help. #4
Erskine makes those rear PTO driven snow blowers.Seem to be pretty decent units.
2006 International 9400i (A52748)
2006 International...
New Bobcat 18" Bucket (A50774)
New Bobcat 18"...
2016 Nissan Frontier Ext. Cab Pickup Truck (A50323)
2016 Nissan...
2018 Bobcat T870 Skidloader (RIDE AND DRIVE) (A50774)
2018 Bobcat T870...
2012 Ford F-450 Altec AT200A 30FT Bucket Truck (A50323)
2012 Ford F-450...
John Deere 2755 (A50120)
John Deere 2755...
