NX4510 HST Cab A/C issue
   / NX4510 HST Cab A/C issue #1
Kioti Dave
Leduc Alberta Canada
2016 Kioti NX4510 HSTC
The A/C on my 2016 NX will 'flicker' on and off. The problem seems intermittent. Dealer came and looked at it, and it behaved when he was looking at it. Only after he left did it start acting up. High and low side pressure seemed ok. Screens are completely clear of debris. When it works, blows really cold, but sometimes, the compressor turns on and off every few seconds, sometimes it will do this for a full hour, and cab will not cool. Anyone else see anything like this? As well, with A/C on, you cannot turn up the heat and get heat in the cab. In the winter when the windows fog, I like to turn on A/C to defog the windows, but can't keep the heat coming out. Any thoughts?
   / NX4510 HST Cab A/C issue #2
Can't help with the intermittent on/off thing. Sounds electronic in nature, so replacing the controller may help.
Regarding the windows fogging, I was having the same issue when turning on the AC to defog. Soon as you turned the AC on, all you got was cold air. I did some searching on this forum and deduced there was a kit from Kioti that included a new control module and blend gate. Goes in the top of the cab. The dealer installed it for me under warranty, and I now have better temp control. The part number was TE16-A0083A. The corporate techs knew what it was right away when my dealer called them.
Recommend you have your dealer install the kit above and see if you continue to have the intermittent issues. Replacing it may solve both your problems.
Thanks. I was asking my dealer about that kit. I will have to get one. Thanks for the info. I think the A/C problem might be in the cab. Is like that when the cab starts off really hot. Do you have remotes on your NX. Mine seem to run really hot, near 175 degrees. You have much warmer weather than I do in Canada. So far pretty happy with NX.
   / NX4510 HST Cab A/C issue #4
Dave---yes, I have two remotes. Not sure about the temp of them though, as I haven't used them yet. Apparently, the previous owner used them to run a hydraulic auger. I've since installed a third function for future use, and removed the hoses that were ran to the front of the tractor.
And yes...it's HOT here in South Texas. I get temps of up to 130+ degrees in our attic on hotter days. Most Summer days, we get between 100-105 degrees ambient. That's when I really, really like the AC in the cab. :thumbsup:
Yes, with those outside temps, you would be medium rare in no time without A/C. The NX really puts out some nice cold air..... when it works. Have a good day.
   / NX4510 HST Cab A/C issue #6
Dave - I'm sure you and the dealer checked the compressor belt for sufficient tension, right? I'm mentioning it just in case. An stretched or glazed belt can slip and mimic intermittent short cycling of the compressor. I had to retension my belt recently when this happened. The AC started cutting in and out during several hours of heavy loader work in 90 F heat. After retensioning, all was well again.
Justman777, what year is your NX? Mine is an early 2014. I've always been able to run the AC simultaneously with the heat to prevent fogging, but I'm still curious about the control module and blend gate kit. I'm wondering if Kioti might have had a problem with a run of 3rd party AC parts.
   / NX4510 HST Cab A/C issue #7
Threepoint, I have a 2018 model. I'm not sure there was a bad production run, but the kit was called a control assembly "upgrade" by the corporate Kioti tech.
Thanks for the input. Belt seems ok. I plan to get the kit mentioned in this thread as the 2016 NX will not run heat with the A/C on. Will see if a new module will make a difference.
Thanks for the info. Contacted dealer, and the kit is on order and will be installed on warranty. If you use your tractor a lot in winter, you need to be able to turn on A/C with heat to keep windows clear.
   / NX4510 HST Cab A/C issue #10
Cool! :)
I'm not sure why the kit wasn't installed at the factory. Seems like it'd be a factory default.
SCAN FOR HAULING AND FINANCING INFORMATION (A50459)
SCAN FOR HAULING...
2017 John Deere 544K-II Wheel Loader (A50490)
2017 John Deere...
2018 JOHN DEERE 750K LGP CRAWLER DOZER (A50458)
2018 JOHN DEERE...
2008 Ford F-250 Reading Service Truck (A48081)
2008 Ford F-250...
2016 International TranStar 8600 Toter Truck, VIN # 3HSHXSNR5GN056882 (A48836)
2016 International...
UNUSED CFG SKID STEER AUGER SET (A50460)
UNUSED CFG SKID...
