Observations on Switch to Synthetic Oil
   / Observations on Switch to Synthetic Oil #1
webbmeister
Wauconda, Illinois
New Holland TC25D
Having read these threads in some depth, I decided to switch to synthetic at today's oil change. The product purchased was Amsoil 15-40 HD Deisel Marine oil. Before draining the existing oil, a pint of Amsoil engine cleaner went in and ran for about 20 minutes.
The tractor just hit 250 hours, and in spite of having had 4 previous oil changes, what came out of the tractor was black and thin. Some of the thinness can probably be attributed to the cleaner, and the blackness to the cleaner and soot.
So, in went a new oil filter and 4.2 quarts of the Amsoil. The engine started up, let the oil disperse through the engine, and shut it down. Oil level check showed just right. Started the engine again, and just let it run for awhile. Then put it in gear, engaged the MMM, and did three acres of hills. Here are some subjective observations:
1. Engine quite a bit quieter.
2. Checked max RPM - "seemed" like it was topping out in the low 2900's - previous (from memory - getting old - could be wrong) was mid 2800's.
3. Engine definitely ran cooler - low to mid green on the steep hills, rather than high green.
4. Engine seemed to bog less, requiring less backing off of the hydro pedal, going up the steepest hills.
5. When finished, after disengaging the MMM, dropped RPMs to minimum. Definite difference here, too. It ran a smooth and consistent 1100 - about 100 higher than before. Shut down engine.
6. Three hours later, started engine again. Just a tiny puff of black smoke then exhaust became invisible. Previously, there was more smoke and it was blue before it would clear up.
7. Shut her down, checked the oil. Amber, no hint of darkening, and the same consistency as when it went in.
Again, these are entirely subjective observations - nothing scientifically measured. I'm skeptical by nature, though, so it takes a bit to sell me on something. Not sold yet, but surprised at the up front difference. I'll keep an eye out as time passes, and at 300 hours, I'll change the oil again and see what the drain looks like, and I'll switch all the hydraulic fluid to ATH from Amsoil and see how that goes.
Bottom line for now: Pleasantly surprised at degree of difference.
Jim
   / Observations on Switch to Synthetic Oil #2
Diesel oil should get black and "sooty". It is dispersing the soot from combustion.
I run Mobil one in my cars. Fewer oil changes = more time to play on my tractor.
Bob
   / Observations on Switch to Synthetic Oil #3
What is the price on that Amsoil diesel motor oil? Also, where is a convienent place to get it? Any of the Auto parts places carry it or is it strictly through Amsoil dealers?
Thanks,
John
   / Observations on Switch to Synthetic Oil #4
The Amsoil web site has all the prices. I buy over the Internet and have it shipped to my door. None of the local auto parts store in my area carry it.
   / Observations on Switch to Synthetic Oil #5
You can also become a "dealer" for $30 per year. If you have a fleet of vehicles and tractors like I have, it is worth spending the money to become a "dealer". And, yes, I have spent the money at Blackstone labs and I am convinced that Amsoil, Royal Purple, and Red Line oils are the highest quality oils you can buy. I only pick Amsoil out of that group because the price is better than the others and the lab results are almost identical.
   / Observations on Switch to Synthetic Oil #6
Its only $20 a year or $10 for 6 months to become a preferred customer (PC) and buy at dealer cost. I know several guys with engineering and electrical contractor business's that are PC. They buy several $1000 worth of diesel oil a year this way for thier company trucks.
   / Observations on Switch to Synthetic Oil #7
Webbmeister, in my opinion ,you are using the best oil out there for the price.Don't stop with your tractor. Use Amsoil in your vehicles for 25,000 mile oil drains.
   / Observations on Switch to Synthetic Oil #8
Rotella T "synthetic" is just as good. Save money too.
   / Observations on Switch to Synthetic Oil #9
SHHHHH! You'll put a dampner on the paid product endorsements for AMSOIL!....LOL
   / Observations on Switch to Synthetic Oil #10
I didn't know rotella T had a 25,000 mile oil :rolleyes: :confused:
2016 CATERPILLAR 325FL EXCAVATOR (A51242)
2016 CATERPILLAR...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51243)
2012 VOLVO DBL...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
