Off Topic question
   / Off Topic question #1
Lockport
Platinum Member
Lockport, Manitoba
Bobcat CT235
Seeking the wisdom of experience, I have a small Kubota diesel engine powering a generator and small droplets of water are evident in the exhaust pipe. What is a probabal cause of this? It has 5000 hours and I have never had the time to even to a valve height adjustment, although its on my list.
   / Off Topic question #2
Is the engine liquid cooled? Have you had to add any coolant lately? May be a leaking head gasket.
   / Off Topic question #3
It could be a simple as a cold exhaust pipe condensing moisture.....a small diesel takes a while to warm up...hence the exhaust is cool for a while but warm enough to condense water.
Just a thought...hopefully it isn't too complicated or expensive to fix.
Yes it is. In fact it circulates coolant on a big highway truck as it is plumbed into its Caterpillar C-15. Occasionally there are traces of coolant on the Kubota by it water pump. It's hard to tell where it's coming from as this genset is put together in too cramped a compartment and it is hard to see amongst all the hoses et al. In fact the firm that made it recently went under, no ddoubt aided by design flaws.
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A55218)
2003 International...
2011 Ford F-350 Knapheide Service Truck (A54814)
2011 Ford F-350...
SKID STEER HYDRAULIC TREE PULLER (A53843)
SKID STEER...
2009 John Deere 1050J Crawler Tractor Dozer (A52377)
2009 John Deere...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A54814)
2016 Autocar...
