Oil Change Amount Ford 5.0
   / Oil Change Amount Ford 5.0 #1
b8200hst4wd
Bronze Member
Jordan NY USA
Kubota B8200 HST 4WD
Hey,
I have a 1996 Ford Explorer with the 5.0 liter engine (302). I misplaced the manual and I was wondering what the oil change amount was with a filter change?
   / Oil Change Amount Ford 5.0 #2
Never owned a Ford 5.0, and rarely change oil except for the tractors. My routine is to go by the marks on the dipstick after running the engine for a few minutes. Unless the engine has the wrong 'stick, you can't go wrong.................chim
   / Oil Change Amount Ford 5.0 #3
I had a 1995 Ford van with the 5.0 liter engine. It took 5.25 quarts. However, vehicles with the same engine may vary on oil capacity due to oil pan differences to fit that frame. Buy 6 qts and use the dipstick as Chim suggests.
Jeff
   / Oil Change Amount Ford 5.0 #4
5 quarts + filter, so buy 6 quarts, pour in 5 and then check. Oil filter sizes are different on various 5.0s as well. My old bronco uses 6 quarts but has a 1 quart filter, FL1A. My friends mustang which has a tiny tiny engine compartment compared to my truck uses a FL400S? or somthing like that which takes less than a quart.
   / Oil Change Amount Ford 5.0 #5
Most of these 5.0L motors in Ford trucks take 6qts. I know yours has a different pan then any other, and it may have anouther size filter also. I would go with what others are telling you. Dump in 5, then check the stick. The totals they list in the manuals are never spot on anyway, so I usley don't fowel them. The stick doesnot lie.
Yeah, That's what I was thinking 5qts then dip it...
It takes a Fram PH8A filter... Quite Standard
New Holland B95 Backhoe (A50490)
New Holland B95...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
2012 John Deere 7230R (A52748)
2012 John Deere...
2014 PETERBILT 388 (INOPERABLE) (A52472)
2014 PETERBILT 388...
2021 FORD TRANSIT 250 CARGO VAN (A52576)
2021 FORD TRANSIT...
2000 Ford F-150 Pickup Truck, VIN # 1FTRX17W7YNA75070 (A51572)
2000 Ford F-150...
