Oil & Fuel Oil Change Oops
   / Oil Change Oops #1
KenGod
PA
CK2610HST
Even Good Dealers like my local one have bad days, I went to pick up oil and filter for the ck20. I couldn't remember how much oil it took, so I asked the counter. He told me 1.9 gallons and gave me 2 gallons of oil and filter.Got home changed oil, took dipstick out to check oil level before I started it and oil was shooting out of the dipstick hole like a fountain.:eek:
I had to drain out about 1 gallon before The level was right.
Well even a good dealer can make mistakes, I called him about it and he said stop by, he will give a gallon of oil for free.
He cant take all the blame tho, I should have not been so lazy and checked the manual myself.
If nothing else,we should learn form our mistakes, Im sure I will always know my ck20 takes .9 gallons of oil.
Ken
   / Oil Change Oops #2
Ken
I still think you are figuring too much, Ken. The book for my CK20 says .69 gallon not .9. Am i wrong or are is it you.
rimshot
   / Oil Change Oops
You very well might be right. I just drained the oil back out till the dipstick showed full.
Either way I know its less then one gallon.
Ken
   / Oil Change Oops #4
Ken
It would not have hurt to check the oil level a time or two as you went along refilling it.
   / Oil Change Oops
Lbrown,
So True, I could have avoided that whole mess if I wasn't in a rush.
   / Oil Change Oops #6
That's not a bad oops to have......starting it up with no oil would be a big time OOPS!!......Mike.
   / Oil Change Oops #7
rimshot
Now we can take an average, my manual says .84 U.S. gals.
   / Oil Change Oops #9
You could also start it up with the filter double gasketed.:rolleyes: It drains the oil fairly quickly!
   / Oil Change Oops #10
You are absolutly correct my friend:)
When they say to remove the old gasket, they really, really, really mean it, and don't ask me how I know these things
Tom
Seppi Mini BMS 85 Mulcher excavator attachment (A51039)
Seppi Mini BMS 85...
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
2020 John Deere 870GP Articulated Motor Grader (A49461)
2020 John Deere...
2008 Ford F-250 Ext. Cab Pickup Truck (A49461)
2008 Ford F-250...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
