Spencer
Veteran Member
- Joined
- Jan 2, 2002
- Messages
- 1,267
- Location
- Western Michigan
- Tractor
- NH TC33D w/R4 Tires, Rear Remote, Hydraulic Toplink, 2 Auxiliary Work Lights, 7308 Loader w/Kasco Uni-Hitch (Quick Tach)
I just got done changing the hydraulic fluid in my tractor (300 hour service). I used two different drain pans and one large 5 gallon plastic storage bin to drain the fluid into. I realized half way through the process that it would be a lot easier to clean up these drain pans if I lined them with a plastic garbage bag first. It was too late to try it on the 5 gallon bin but I did line the two drain pans with plastic bags and it made the clean up a snap. I use to always waste 10 or 15 paper towels getting the last of the oil/fluid out of the drain pan. Today after I poured the fluid from the pans I just tied up the garbage bag and threw it away.
This may have been covered here before or some of you may have tired this yourselves. I hadn't seen it covered so I thought I would pass it along. By the way I use those disposable latex gloves when changing fluids and they work great also.
