Oil drain pipe came loose from crank case
   / Oil drain pipe came loose from crank case #1
Vigilant
Bronze Member
Instead of the cap coming off the oil drain tube as it should, the tube and cap unscrew from the crank case. Can the tube be welded to the crank case? Thanks. This is on a John Deere GT275.
   / Oil drain pipe came loose from crank case #2
Ummm.... Crankcase may be cast iron if it actually is engine block it came out of... Don't think I would want to try welding to engine block if its cast iron unless you use a nickel based welding rod and have a way to control heat....
Might be good question to ask in welding forum...
IF it just unscrewed, I would clean thread in crankcase and on drain pipe and use something like LOCKTITE 565 thread sealant/locker and put it back together....
LOCTITE 565 - Thread sealant - Loctite
Dale
   / Oil drain pipe came loose from crank case #3
I had a quick drain on my Kohler that would come unscrewd constantly or would pull apart. So I replaced it with a brass nipple, elbow, and drain cock.
   / Oil drain pipe came loose from crank case #4
Yeah... Have quick drain on a Briggs on mower and it is mounted so short it dribbles on mower chassis when trying to change oil, next oil change, longer "pipe" and brass valve (drain cock) .... Probably going to find same situation on my standby generator at oil change...
Dale
   / Oil drain pipe came loose from crank case #5
As I talked about in my previous post. This is what mine looks like. One of the best changes I made to my mower.
VULCAN STAINLESS STEEL STEAMER (A51248)
VULCAN STAINLESS...
FRONTIER MG20F LOT NUMBER 83 (A53084)
FRONTIER MG20F LOT...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
UNUSED FUTURE FT-SCW46 STEERABLE COMPACTING WHEEL (A51248)
UNUSED FUTURE...
91013 (A48082)
91013 (A48082)
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
