Oil leak from front of Clipper 400 gear box
   / Oil leak from front of Clipper 400 gear box #1
rbstern
Platinum Member
GA
LS MT225E, Yanmar 2210
My rotary cutter is about 18 months old, with maybe 35 hours of use on it. Last time I was at my property, I noticed it had a fair amount of oil on the front of the gearbox, and on the cutter deck in front of the gear box. It was also the first really cold spell this year, so I am wondering if the cold affected a seal.
Should I just top off the oil and monitor for oil leakage, or do I move right to "its in need of some type of maintenance (and here's what it is...)?"
   / Oil leak from front of Clipper 400 gear box #2
You probably have a seal that is leaking your oil.
Idaho2
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2024 JOHN DEERE 331P-TIER SKID STEER (A51246)
2024 JOHN DEERE...
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52576)
2023 TAKE 3...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A52748)
Michelin CARGOXBIB...
