Oil & Fuel Oil out of exhaust
   / Oil out of exhaust #1
woodyacres
SE Michigan
Kioti DK35SE
Hi Everyone,
I keep my DK35 in the garage and everything in front of my tractor is sprayed in oil. Is this normal during start-up (it is winter now)?
   / Oil out of exhaust #2
I think you'll find it's nothing more than exhaust soot? They all do it due to the foreward facing exhaust discharge;I'm not sure thats better than the verticle option :confused: If, in fact, it is oil; Houston, we have a problem :eek:
   / Oil out of exhaust #3
As Patches said , i think you will find it is soot . Condensation forms inside the exhaust and comes out as a sooty water spray when started . You may try pushing/tying an old air cleaner element over the stack to catch the spray on startup and then remove it once the tractor is outside . My truck does this also and it's always shedded . It's hard to get off a surface as it stains .
   / Oil out of exhaust #4
Dan,
I would check and see if it is in fact "fresh" oil coming from the exhaust. If it is you have a cracked piston ring. The 20 hp Kioti that I had prior to my DK35 had a cracked ring and did the same thing. It is the oil in the crankcase pushing past the piston. A good check is keeping an eye on you oil level. If both are occurring, it is pretty much a sure thing that a ring is cracked.
2009 MIE Conter Console Police Patrol Boat with T/A Boat Trailer (A50324)
2009 MIE Conter...
2000 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
2000 Mack CH613...
2016 Ford Explorer...
2011 INTERNATIONAL PROSTAR PREMIUM (A52472)
2011 INTERNATIONAL...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2014 Ford F-150...
