Oil Pan Drain Plug
   / Oil Pan Drain Plug #1
kells
I cannot get the drain plug off on my Iseki, Who ever tighten it last time just cranked on this thing. The head is now stripped as well. I have tried Vise grips,heating the plug and banging on a smaller socket but i cannot budge the plug, any other ideas?
   / Oil Pan Drain Plug #3
Mine was so tight when I got it I had to take a big crescent wrench and a hammer to loosen it. Might be the refurbishing people overseas are using an air wrench?
Anyway, keep putting PB blaster on it for a couple of days and then try it again. If it is rounded off, you might end-up dropping the oil pan and easy-outing it. Also you might try grinding a slot for a large screw driver, or welding something on it and using that to turn it. Good luck.
   / Oil Pan Drain Plug #4
Pipewrench and a cheater bar.
   / Oil Pan Drain Plug #5
Use a pipe wrench, it won't slip like vise grips.
Thanks guys I will give all of them a try this week and hope one of them works. Thanks again.
Toro Workman HDX-D Utility Cart (A50322)
Toro Workman HDX-D...
YOKOHAMA - GALAXY 16.9-24 DIAMOND BUTTON TIRES (A52748)
YOKOHAMA - GALAXY...
2003 John Deere 990 (A50120)
2003 John Deere...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51573)
IMPORTANT PLEASE...
19200 (A50324)
19200 (A50324)
John Deere 6068D (A50120)
John Deere 6068D...
