Oil pan removal on 2012 max28xl
   / Oil pan removal on 2012 max28xl #1
Drewintoledo
Bronze Member
Ohio
LS MT225HE
Trying to help a friend. Says he needs to drop the oil pan but front driveshaft is in the way. He says "it looks like it's in a tube" and he doesn't understand how to drop it.
Any information is apprecaited. Does anyone have a service manual they can pass me?
   / Oil pan removal on 2012 max28xl #2
Did that on my 3016. exact same engine. if i remember right you loosen the clamps on the rubber boot on the front axle then slide it back. should expose the u joints. There is a snap ring or C clip that you remove which then lets you slide the shaft off the stub.
but from the online parts it might be as simple as removing a C ring and slide the collar back then you should be able to remove the whole shaft. might be 2 bolts holding a stabilizer tube...
Thanks for your reply. Here's what my friend wrote when I sent him your infiormation: "Sadly that does not describe my situation my shaft has no rubber boots I'll have to go underneath and have another look at it. I so no boots no snap rings do anything just a tube thanks for the help"
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
BREWSTER DRAWWORKS WITH TWIN CATERPILLAR ENGINES (A50854)
BREWSTER DRAWWORKS...
2007 MACK GRANITE ROLL OFF TRUCK (A51222)
2007 MACK GRANITE...
2016 FREIGHTLINER M2 DAY CAB (A51222)
2016 FREIGHTLINER...
2018 East Texas 20ft Utility Trailer (A49461)
2018 East Texas...
2004 Big Tex 10PI 18ft T/A Pipe Top Utility Trailer (A49461)
2004 Big Tex 10PI...
