oil pressure and temperature
   / oil pressure and temperature #1
farmerhulio
fairbank PA
farmall,and mustang
I have a mustang 442 skid steer loader with a kubota 1902 engine in it. What i need to know is what is the correct oil pressure at start up and at operating temperature also what is the proper operating temperature. The skid steer is a 1988 model. thank you
   / oil pressure and temperature #2
I see you have no responses so I will only say that while I don't know the specs for your particular motor, most motors will have 40 to 50 psi oil pressure at start up, maybe more on a cold day with thick oil. Most will idle warm around 25-30. Running temps are usually 180 to 220 warmed up depending on the thermostat and load.
MILWAUKEE 52" HIGH CAPACITY MOBILE WORKBENCH (A51248)
MILWAUKEE 52" HIGH...
2014 Ford Explorer Sport AWD SUV (A51694)
2014 Ford Explorer...
(1) UNUSED 7000# DROP AXLE W/ BRAKES (A51247)
(1) UNUSED 7000#...
John Deere 2440 Tractor (A52384)
John Deere 2440...
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
HARDEE RD72M LOT IDENTIFIER 141 (A53084)
HARDEE RD72M LOT...
